[ - If somebody or something turned the nut under that "loose wire", there's definitely a chance that it's a factor.- ]
Yes, it is a concern that it has been tampered with, I just didn't think it would cause a runaway when it has been working well beforehand, and I didn't see signs of recent change. Of course it could be that it had played up previously and that is why it was messed with.
[ - The high pressure side consists of the IP itself, the hardlines, and the injectors. You must crank the engine to move fuel through the HP side. So bleeding the system consists of using the ring and hand primer, followed by loosening the hex collars at the injectors and cranking the engine. When bubbles stop and raw fuel flows, tighten the collars. You've just bled the fuel system. If you don't get fuel at the top, you've likely got an IP problem. - ]
Good I will give that a try, (that spanner size wasn't in my kit, may be 20+ mm). Not looking at the runaway at the moment I am just trying to get it to fire again, and worry about the over-revving once it starts.
[ - Don't forget to put the fuel rack in mid position to ensure that the pump will be delivery fuel. If this nut was lose, then how do you know the fuel rack is positioned to pump fuel ? If the rack is shut off completely - ie at the extreme end, then NO FUEL WILL BE PUMPED IF THE ADJUSTMENT IS OUT OF WACK - sorry about the large case letters, but this is important. - ]
I guess I am thinking that I can loosen off the hex clamp, as Greg says, and crank the engine. If I get fuel pumping out then that should tell me the injector pump is operating. If not then I can move the throttle lever and try again, which, I think is what you are saying. I feel reluctant to crank it with the throttle opened up, at least at first.
[ - DISCONNECT THE AIR CLEANER FROM THE INTAKE MANIFOLD AND HAVE A ROUND PIECE OF 3/8" THICK (MINIMUM) PLYWOOD AT THE READY TO COVER THE INTAKE IN CASE OF A RUNAWAY. - ]
Yes I saw this issue while searching on runaway engines, where some did not respond to the governor shutoff.
