Johndeere3720
Padawan Tractor Learner, Advertiser
- Joined
- Mar 14, 2009
- Messages
- 6,477
- Location
- NW Oregon
- Tractor
- Bobcat T62, MT55, E42R, E10, John Deere 4100
Thats pretty slick Kyle. :thumbsup: I got to say, now that you bought your first implement, You will start looking for your next one. :laughing: With your carry all, get some lynch pins and a category 1 pin for the top. With the deck you want to put on it, It really would depend on what you plan to use it for. If it is more heavy duty used Than i would opt for the treated 2x8s. Plywood would really depend. I would recommend 3/4" thick so you still have the capacity that you will desire but it doesn't come cheap. To line up the holes when drilling, remove the carry all from the tractor and flip it up so the half facing the tractor when attached is flat on the ground. Then use "C" clamps and hold the lumber to the carry all so you can mark where the holes are to be drilled. When you get them drilled, use carriage bolts (flat heads) so you can slide things easily across the deck and tighten them down (using washers recommended).
