CountyLine Carryall
/ CountyLine Carryall
Oh, and I assume it is pretty easy to add a simple deck to it?
/ CountyLine Carryall #4
Yes it's a good buy, can be used as a carryall platform, weight box, and my favorite as pallet forks and I rigged them up to attach to my buckket. I find it very good for collecting brush, tree branches cut logs etc,
All the ones I've seen come with pre-drilled holes in the angle irons for attaching things.
Go get it.
Go get it.
Do you have one? How has it held up?
Also, do you think it will fit in the back of a Ford Explorer?
/ CountyLine Carryall #8
I love mine and use for moving just about everything...
yes it will fit in a PU truck...two guys can easily load it...
[edited] sorry "Explorer"....I think it might but don't hold me to it...
get some 2x8 PT and some carriage bolts to make a simple platform deck...
get the bolts, nuts and washers etc. while you're at TSC and save some $ by buying by the pound rather than the package at other stores...
Thanks. Still not sure that I will get it. I'll have to check it out when I go to the store tomorrow...
/ CountyLine Carryall #12
I do. I think it's a decent value, probably couldn't build one for the price.
Mine works fine. Can't remember how wide it is, but you might be able to carry it in an Explorer if you turn it sideways.
NOT quick hitch compatible, will need modification/adaptation.
That's a nice carryall! :thumbsup: I will not need to worry about the quick hitch...
/ CountyLine Carryall #14
I bought a carryall frame locally off Craigslist for $40.00. It has a 33X60" platform with stake pockets all around. The mast for the top link is a horseshoe shaped pipe. I put a headboard and sides on it.
/ CountyLine Carryall #15
I bought one of these last year. At the time i think i paid $99.00 for it. it was worth it. Since my loader tractor is almost worthless i use it alot most pallets will slide on it and if done slowly you can move them around easly. i put wood on the back and have a designated pallet that i attach to it and it makes a nice box i pick up / move logs firewood. i have also used it to load heavy things in the back of my pickup.
This will fit in the back of your SUV and can be lifted by one person.
/ CountyLine Carryall #16
/ CountyLine Carryall #17
I got one of the 1000# capacity ones in July of '09 and built a wooden platform/box for it. It saw a lot of use over the summer and fall months, especially in 2010, when I was doing a lot of trail-building in the woods. This past summer, I managed to crack a weld backing into a tree, but otherwise it seems pretty sturdy.
I somehow shoehorned the carryall frame into the back of a Toyota Corolla, so it will probably fit into your vehicle.
BOB
/ CountyLine Carryall #18
I got one from TSC for $99. last fall and had enough good weather to get the deck and back attached. I thought it was a good buy and it's heavy duty.
Used rough cut 2x6 for the deck and 1x 8 shiplap boards for the back.
My situation is I've built it so heavy my poor ole Brockway will have issues lifting it. I suspect I'll be rebuilding or replacing the cylinder this spring.
BOB
Thanks, we already got it and it fit...
/ CountyLine Carryall #20
Well you could... but it would cost you forty bucks more than it should ;)
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
(1) 48"X18' ADS DRAINAGE PIPE (A60432)
(1) 48"X18' ADS...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
John Deere 5055E (A53317)
John Deere 5055E...
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
UNUSED IRMC HIGH END MASSAGE CHAIR (A60432)
UNUSED IRMC HIGH...
