Lever wont stay on
   / Lever wont stay on #1
ole farmerbuck
Kansas
2010 Kubota M7040
Have another question here. On my new M7040,when i tilt the rear blade one way, the lever stays on like it is suppose to till its tilted all the way but it wont stay going the other way. I have to hold it there. Is there an adjustment or do i need to call the dealer?
   / Lever wont stay on #2
Can you be a little more clear? Most hydraulic controls are supposed to "spring return to center" and not stay "on".
If i want to move my blade all the way to the left, i push the lever all the way and let go. When the blade is all the way, the lever pops back as it should. But when i pull the lever all the way back to move the blade the other way, it wont stay at all. I have to hold it there. It just pops back as soon as i let go.
I dont usually push or pull the levers all the way since usually a little bit of travel is all thats needed. Its just that i know the lever should stay until the cylinder has reached its end of travel and then pop back to center.
   / Lever wont stay on #5
Sounds like the wrong valve might be installed.
Holds one side only?
Pops back from other?
Either wrong valve type or a spring loaded ball is not working.
   / Lever wont stay on #6
I have never seen a valve like that-except on a logsplitter. Hopefully someone can help...
My log splitter stays on until the cylinder retracts all the way but doesnt when going forward. Just like its suppose to. Like i say, only one lever and only one way is this one messing up. The other lever will stay either direction until the end of movement.
   / Lever wont stay on #8
How do you know??
   / Lever wont stay on #10
Why wouldnt it? It does the other way and the other 2 levers stay till end of cycle.:confused2:
Just because the other lever stay on pressure detent, doesn't necessary mean this one is designed/meant to do the same thing. Pressure detent is a feature that only is safe on certain applications, and pressure detent have to be subject to safety precautions. "Spring to neutral" is a safety feature that make sure the actuator stops motion if operator gets an "heart attack".
If you have a valve from the "garbage bin" that operates your hydraulic applications with pressure detent, it is a good idea to review if that make common sense.
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2021 Doyle 8 Ton Trailer Tender (A52128)
2021 Doyle 8 Ton...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2017 Chevrolet Malibu (A50324)
2017 Chevrolet...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
