Lever wont stay on
   / Lever wont stay on #21
Kim is right.
All of the older larger, true AG tractors had remote valves that detent both ways until the end of the cylinder stroke. Most of them had a way to defeat this feature if desired. I remember on the JD's it was a little plastic tab in the lever slot that you flipped up. That locked out the "auto detent" so it was non-functional if that's what you desired.
I'm not sure if they still offer that feature on the larger Ag tractors. Been a long time since I was a real farmer and had tractors that big.
I haven't ever seen that feature on a CUT. I think it's mostly because there are few people who pull wheeled implements all day long that require remote hydraulics to lift and lower.
Mark
My dealer sent a tech up the other day to check the remotes out. He said they are replacing all 3 of them. They said Kubota rep said if they installed and tightened to book specs, then they are too tight! What about a service bulletin stating not to tighten to specs? Oh well.
SAKAI SV414D SMOOTH DRUM ROLLER (A52709)
SAKAI SV414D...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
Ryobi BS 900 9" Band Saw (A59076)
Ryobi BS 900 9"...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2025 AGT H15R Mini-Excavator with Dozer Blade & Pilot Controls  (New/Unused) (A59225)
2025 AGT H15R...
