How would you cut a 1" thick piece of cast iron?
   / How would you cut a 1" thick piece of cast iron? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
I'm not sure if it's possible or practical. I was telling my neighbor about a couple pieces of old pipe i found next to a woods road (trying to figure out a way to break them up into manageable pieces to get the $800+- scrap value) when he mentioned he could use some of it for grates in his maple syrup evaporator. That sounds like more fun... suggestions anyone?
   / How would you cut a 1" thick piece of cast iron? #2
portable bandsaw or saws all. If it is really cast iron. If it is poorly made CI it will eat blades.
Steel you can torch it.
   / How would you cut a 1" thick piece of cast iron? #3
would a snap cutter not work to cut a managable size piece?
Thanks.
He wants several 6" by 3ft pieces, seems like it would take a lot of sawsall blades.
it's worth a try though. i'll bet they'll make good grates.
   / How would you cut a 1" thick piece of cast iron? #5
Don't know what kind of tools you have available.
Plasma, carbon arc, demo saw.
I had to do a search to see what you meant. Guess I should have mentioned the pipe is 31" OD. If it's possible, he may find it cheaper to take it to a machine shop.
   / How would you cut a 1" thick piece of cast iron? #7
A chain cutter rental, would seem in order, otherwise a pair of safety glasses, and a sledge hammer...........
YouTube - Removing Cast Iron Pipe
~Scotty
OH! Just saw the 31" OD! Wow!
   / How would you cut a 1" thick piece of cast iron? #8
$800+ for scrap metal sounds like fun to me...wish I could stumble across something like that! I'd find some way to get it to the scrap yard, I guarantee that...
   / How would you cut a 1" thick piece of cast iron? #9
I'm missing something. How do you get a 6" X 3' piece. out of a 31" diameter pipe? ~S
   / How would you cut a 1" thick piece of cast iron? #10
its obvious.. the answer is
2017 HITACHI ZAXIS 250LC-6N EXCAVATOR (A51246)
2017 HITACHI ZAXIS...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
HUTCH MASTER 12' OFF SET DISC HARROW (A51247)
HUTCH MASTER 12'...
2019 CATERPILLAR 316FL EXCAVATOR (A51246)
2019 CATERPILLAR...
