We have learned by many posts that you have to have dry air going into the plasma cutter to cut with because it will burn up consumables and the machine don't like it.
I have a question, If you have dry air going into the machine like is recommended but the metal that you are cutting is wet or damp is it ok to cut that metal or should you let it dry first? I have some metal off of the top of a building that I want to cut up but don't want it inside the garage to do it and it don't look like it is going to dry up anytime soon. The metal has some salvageable sections that I can use and some that has too much rust to use. All of the metal that I have cut so far has been dry, I just want to cut this up so I can sort the good and discard the bad. Thanks.
