How would you cut a 1" thick piece of cast iron?
   / How would you cut a 1" thick piece of cast iron? #41
Assuming I was going to scrap it (I would try and sell it or use it as a culvert myself) I would scribe it with the demo (abrasive saw) then sledge or Jack hammer on it.
Most brittle materials (just did some tungsten blocks, you want to talk about hard) if you scribe where you want it to break (by scribe I mean cut a thin line say 1/4" deep) then give it a hard sharp strike right on the line, often they will crack right along the fault.
So if it was me, and I forgot the dimensions, but I would do a circumferential scribe at about the length of my trailer, then strike it, or Jack hammer it, or drill a hole, put my porta power wedge in and strike the opposite side. and cut the thing into a length that would go on my trailer.
Then I would scribe lengthwise down it on opposite sides, or maybe quarters and repeat the process.
I think it could be done in fairly short order.
   / How would you cut a 1" thick piece of cast iron? #42
Scribe and break or carbon arc are the only two practical ideas I can see on this thread. The most practical idea I can think of is take the stuff in and try and trade it at the scrap yard for something closer to the right shape for the evaporator.
   / How would you cut a 1" thick piece of cast iron? #43
I'm not sure if it's possible or practical. I was telling my neighbor about a couple pieces of old pipe i found next to a woods road (trying to figure out a way to break them up into manageable pieces to get the $800+- scrap value) when he mentioned he could use some of it for grates in his maple syrup evaporator. That sounds like more fun... suggestions anyone?
Didn't it occur to someone that this pipe actually belongs to someone else. At the least, it sounds like it's on someone else's property, and that would be stealing. I'm just saying.
Steve
   / How would you cut a 1" thick piece of cast iron? #44
wet material wont hurt nuttin
   / How would you cut a 1" thick piece of cast iron? #45
you can cut just about anthing with a grinder with a good cutting wheel. Prefered horse is a very good brand
   / How would you cut a 1" thick piece of cast iron? #46
Maybe this was overlooked but: the OP'er mentions 31" od x 1" thick.......good luck with grinding that......you must work pretty cheap.......I'll reserve my valuable time to playing tiddlywinks or becoming a part-time skin diver for Roto Rooter......Just kidding..:laughing:
Or just maybe I'd just leave it for someone like you that has all the time in the world to grind it apart......:laughing::laughing:......
Steve
Good point, but I've got that covered. It's on land which my employer manages,and they have no problem with me hauling off any of the junk whic has accumulated over the last 30 years.
   / How would you cut a 1" thick piece of cast iron? #48
You would need about a 100 amp Plasma to make it worth messing with but a generator to run it would be hard to find. How about what JJ mentioned, Arc Air Slice Torch. ( Exothermic) All the craze with Fire Departments who don't have time to wait for the Jaws of Life to cut a roof off. 80# of Oxygen, A battery to power the rod stricker and some slice rods. They cut anything. Often used to demolish bridges. Easy to run and not as expensive as Cutoff Wheels. If you were closer, I would loan you mine. Or if you can find a super large generator, A Plasma would make short easy work of it.
   / How would you cut a 1" thick piece of cast iron? #50
if i was doing it i would try to sell it as a unit, get a farmer to drag it out and load it with a big tractor. now if i hadto cut it up i would grab my plasma cutter and get a big PTO tractor genny and start slice and dice! any farmer will have a pto gen to keep the milk cold when the powers out. the HAVE to milk 2 times a day power or not.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A51247)
UNUSED CFG...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
