My new to me 1970 Ford 2000
   / My new to me 1970 Ford 2000 #11
Before you tear it apart to try and fix the lift problem, try adding a little extra oil to the rear end. I had one for many years and this simple fix cured the trouble I was having with the lift. My problem was caused by a plugged-up inlet filter on the hydraulic pump. Changeing that filter is quite a job, which requires splitting the tractor. My lift became eratic, sometimes it would lift fine, other times it would not want to lift at all. I was amazed that adding just about one quart extra oil above the normal fill level made that lift perform flawlessly over the last several years I owned the tractor. That extra allows oil to get into the pump by bypassing the plugged inlet filter. It may not be a "proper" fix but it sure worked good for me. My tractor was also around a 1970 and had around 6000 hours on it when I got it and close to 9000 when I sold it. It was starting to loose compression and probably in need of a rebuild. I knew this because it was starting to like a little shot of ether for cold starts. All in all, it was a good machine that I was able to sell for several hundred more than I paid. The only thing it needed in them 3000 hours, other than normal oil/filter changes, was a resister in the dash that controlled the readout of the fuel and temperature gauges. If you start to see funny readings on these, before you waste money on a thermostat (as I did), go get one of them $30 resistors from your local NH dealer (they know all about the problem which you will definitely have at some point if you keep the tractor long enough). I really liked that little 3 cylinder diesel which seemed to have more guts than a same-age 3-cylinder gas 3000 that I had, and it would also do almost twice the work on a tank of fuel. As long as it has had good maintenenece, and well under 9000 hours, you should see many years of good service from that tractor. I must say however, unlike a few others here, I still like my "red-belly" 1951 8n, better than I ever liked that 2000 and I cant imagine ever wanting to get rid of it. It is still easier to find parts for and surprisngly good on gas. With gas being so much cheaper than diesel these days, It may be cheaper to do low-hp work with that 8n than a modern diesel CUT.
what is the reason for spliting the tractor to remove the inlet filter to the pump all i have ever done is remove the lift top, pto shaft and pto engagement lever and was able to remove both filters on all the ones i have ever worked on. i have 2 i use personaly and have recently change the filters and have bought and sold about 20 of them and currently or working on three ford 3000 and all of them was done just how i explained. and i can get every part for a 2000 3cyl from the front grille to the pto bearing housing and they are cheap and i like 8n's also but would rather have a 8sp diesel 2000 over an 8n any day
whodat nice to know u can replace the filters without splitting the tractor i've had several people tell me that including the mechanic at my local NH dealer:thumbsup:
also whodat i would like to ask u would running an extra quart of fluid in the rear hurt anything if that would fix the hiccup for now?
   / My new to me 1970 Ford 2000 #14
no it shouldn't hurt anything as long as u dont try to fill it to the top of the center housing
   / My new to me 1970 Ford 2000 #15
spliting tractor means they get more money i try to save the customers money unless the or just a** holes
   / My new to me 1970 Ford 2000 #16
the lift cover on those machines is real super straight forward.
I think I'd service the oil and change it before doing any rebuilding though.
and as wd said. it's a whole lot more tractor than an 8n...
especially with PS!
soundguy
The first thing i done when i got it home was change the engine oil, hydraulic oil, changed the fuel filter. The lift is still doing the hiccup so i got a upper lift rebuild kit i think its called. I will also try to check the filters as Whodat said in an earlier post. I got the upper lift rebuild kit for 11 dollars so i said it being a 70 model machine i'm sure it couldn't hurt to freshen that stuff up anyways. I have the oil to change the transmission oil too but am a little confused the service manual says to use sae 80 ep gear oil and the NH dealer gave me the same hydraulic fluid as in the rear casing is either ok or which should i listen to?
   / My new to me 1970 Ford 2000 #18
i always use hyd oil for both the rearend and the transmission because when they came from the factory they had a seal on the pto shaft and the trans drive shaft where the trans meets the rearend and nine times out of ten one of those to seals leaks and the oil is bascilly in the same sump anyways hyd will not hurt the trans
Thank you whodat when i get back intown from working this week the trans fluid will be changed and the lift cover will be rebuilt hopefully it go's well been reading over the procedure while nothing to do in hotel room except read and watch American Chopper LOL
   / My new to me 1970 Ford 2000 #20
before u put the hyd oil back in the rear end go ahead and pull the lift top off and check for sludge in the bottom of the rearend. i have poured 5 gal. of diesel in the rearend and rocked the tractor back and forth then let set to help desolve some of the trans on the intake filter u might wont to do that also for now if not going to change the filter.
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53473)
UNVERFERTH 330 -...
1965 Rodgers T/A Equipment Trailer (A53117)
1965 Rodgers T/A...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
