My recently finish tree scoop bucket
   / My recently finish tree scoop bucket #31
I've been looking for something like this, and have just about settled on this model. The videos on the WEB site show it on a skid steer, and it looked pretty impressive.
I have a JD 2130 2WD with a Woods 1020 FEL with a Bobcat type quick attachment. The tractor weighs about 6000 pounds. I would be using it mainly to dig holes for planting B&B trees that will need a hole about 4 feet diameter by 2 feet deep. My soil is mixed sand and clay with some small rocks.
For the first batch I rented a Bobcat 331; it worked great and sure was fun. But I think would rather have my own equipment. if this would do the job.
I also wonder if it would be stout enough to try to get up some sweet gum stumps.
Too bad I don't have the skills to build it myself, like some of you have done.
Thanks
Charles
I've never come close to deforming it. it'll dig your holes all day long, no problem. Popping out stumps might require a bit moer abuse, but I'd have zero hesistation about it.
The largest hole I've dug was for a 54" root ball. The hole was 7'X4'. Minimal shovel work to clean it all up. Hardest part was getting the Willow Oak into place by myself.
   / My recently finish tree scoop bucket #32
I think that settles it. This is what I will order.
One question: I assume that for digging large holes, you just dig one scoop, move around a little, dig another, etc. Is that the technique you use?
   / My recently finish tree scoop bucket #33
Nice looking scoop, and I hope it serves you well.
   / My recently finish tree scoop bucket #34
If you're doing a row, like a wind break, then you just jam it in at the appropriate angle (45 deg-ish) plunge it all the way down, and reverse it out cleanly, then drive forward to the next spot and repeat. Then you turn around and come back down the row start popping the plugs out. It takes some practice, but you can get some clean holes. If you don't come at if from opposite side, and try to pop it on the fist try, the hole will be a mess for a smaller 24-36" root balls.
For my really big hole, I just went at it. There was no real technique. Lots of trips out of the "yard" to remove the spoil. Of which there was plenty.
   / My recently finish tree scoop bucket #35
Great thread and I'm hoping for some advice and guidance on this so I can get started.
I have a 75HP Deere 5520 4WD tractor with a QT loader. I also have a Deere QT bale spear and bracket that I would like to use and nount the scoop to. It is very rugged and gives me dual use for less money. A grainy photo from my cluttered barn is attached and hard to see but shows a nice flat mounting surface that I can U-bolt clamp my tree spade to. I'm pretty sure this is a good idea but what do you guys think? I just U-bolt clamp the flat mounting surface to the framework of the bale spear bracket.
Questions I have are how thick is the flat steel mounting plate and how big is it? The 45" diameter has been mentioned and does tghat sound right? My bracket is maybe five or six ft wide so any size would fit. Should I go thicker because of my bigger tractor?
Also, what length is the scoop from the bracket to the tip and would it be flat with the bottom of the loader bracket or is it on an angle?
What size trees do you suppose I could move with this? I'm thinking up tp 12 or so feet"
I realize this is a lot of questions and I don't mean to be a bother so any info anyone can offer is good for me. I'm also searching the commercially made spears for clues but you guys can give me more in the way of practical application. Thank you.
Can't get photo to work .
   / My recently finish tree scoop bucket #36
Here is the QT bracket from a side shot. Front of bracket would be to the left.
See how strong it is?
   / My recently finish tree scoop bucket #37
The tree scoop that I have is 3/8 plate. The bottom is flat and about 16 X 48in. The sides go from 2 in at the tip, to about 18 in at the back. The scoop in the green tractor is similar to mine. You can either do flat plate, or have one piece cut and rolled.
   / My recently finish tree scoop bucket #38
Very helpful, JJ.
Thanks.
   / My recently finish tree scoop bucket #39
JJ--
Who made the yellow one?
   / My recently finish tree scoop bucket #40
For those of you who may be interested in a cheaper, faster solution, I moved about (25) 8-12 ft blue spruce last fall with a scoop I made for the 400x loader on my JD 4120. I have a heavy duty bucket on it that is about 6 ft wide. There are 9/16" dia holes spaced across the front cutting edge of the bucket for mounting a toothbar, etc. I had a piece of 12" wide x 3" channel iron about 30" long that I simply bolted flat-side-up to the bottom center of the bucket using a couple of these holes, plus I drilled another hole further back on center. I honestly spent no money and less than 1/2 hour to make this "scoop" and it has worked far better than I could have imagined. To transplant the trees, I simply use the scoop, which protrudes about 20" ahead of the bucket, to remove 4-5 scoops from the intended planting location, forming a hole. Then I drive over to the tree I want to move, stab at about a 45 degree angle until the scoop is buried under the center of the tree, get off the tractor and wrap a small chain around the trunk, get back on and curl the bucket back and the tree pops right out. Then I drive it over to the hole, remove the chain and slide the tree into the hole. The hole process takes little more than 10 minutes for a 10 foot tree. It works so good in fact that this fall I am going to use it again to move about (25) more that I planted a little to thick a few years back. The channel iron I used for the scoop is quite heavy, aproximately 3/8" thick across the wide (12") section and at the bottom edge of the 3" sides, but close to 3/4" thick at the corners. The tractor bucket is also very heavily constructed, not the light-duty one standerd on the 400X. The first few trees I moved last fall was before the ground softened up, but the scoop penetrated well and no damage occurred to either the scoop or the bucket in spite of the soil being almost like concrete due to a long dry spell in the late summer. Admittedly, the rig worked a lot better a few weeks later after a few good rains, when pushing the scoop was like pushing a hot knife into butter. It is much better for tree survivability to wait until soil moisture content is higher anyhow. Prior to getting a front loader, I used to move trees with a pond scoop on the rear 3 point hitch. That was only a slight improvement over a shovel and ball cart, probably taking 45 minutes on average for moving 10-footers, as considerabe hand digging was still required to pop the trees out and dig a proper hole. The only drawback since getting the front loader is that I get less excercise and have to put in more time at the gym to keep in shape.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
2006 FORD F-250 (A53843)
2006 FORD F-250...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
