Virgin Ground
   / Virgin Ground #11
My experience is any thing that rolls tends to create a hardpan quicker than a plow. Multiple disking may look like you have alot of loose dirt but alot of it is just fluff. I would vote for a moldboard or chisel plow. The disk plow is also good, better than a disk harrow.
Also the less passes you have to make the better. Seven acres sounds like a large amount for a pto tiller. I have done small garden plots with mine. Going from sod to a seed bed in 3 or 4 passes.
   / Virgin Ground #12
I agree. I did about half an acre of "virgin" soil (abandoned farm for about 20 years) and found I needed to run the tiller two or three times to break up the soil and get the brush roots out (initial prep was bush hog). Half an acre with a 6ft tiller still took several hours at least. Part of the problem was large amounts of grape vine roots that wrapped around the tiller and required removing every 50-100 yards on the initial pass. The KK tiller worked fine but I would be looking at something like what Ken recommends to do the initial sod busting if I were doing more than an acre in the future.
   / Virgin Ground #13
I would use a large diameter tiller that covers your tracks and make two passes, done. Something along the lines of a Deere 681 should match your tractor.
   / Virgin Ground #14
We are restoring prairie on 31 ac of land that was last farmed also about 35 years ago. We hired a bulldozer, removed all trees and bushes, filled all erosion etc. Then we pulled remaining roots and saplings out of ground. That was a lot of manual hard labor. Then we planted roundup ready beans. Sprayed it twice (due to rainy weather that washed the roundup) to kill all weeds and non native grasses. Since some non native plants are still sprouting at some places we will do beans one more time this years and plant prairie grass and flowers after that. All is done by no till method with disking only at few places to flatten too bumpy ground. Since the beans price ($12/bushel at 50 bushels /ac) was quite high this year the profit will pay for almost all the investment we will spend in the restoration.
   / Virgin Ground #15
Other than being lumbered off during the 1880s, our land has never been farmed or tilled. I break up new ground with a middle buster. Hardly ideal, but it gets done.
But if I was going to till 7 acres, I'd have a conventional plow, a disk, a spring or spike harrow to drag. Absolutely. There'd be no fussing around. Can't go over it and over it with the wrong implement.
-Compaction
-Diesel cost
   / Virgin Ground #16
If your ground has "laid out" that long, you may want to get someone to come in with a deep subsoiler. We have to run one of these about every two to three years due to soil compaction. I am going to get a much smaller one for our Kubotas as this JD belongs to our renters and won't fit in a lot of places on our other farm.
We found a good used 3-bottom moldboard several years ago that works well, but it doesn't get deep enough to break up the hard pan.
   / Virgin Ground
What if i moldboard plow the 7 acres first then take the tiller to it? basically the same as discing and dragging only i think the soil would have more fluff to it this way. What do you think?
   / Virgin Ground #18
I believe the disc plow that Ken Sweet advertised was originally designed for deep plowing in "new Ground" which still had the occassional underground stump and large root. The disc would simple roll up and over it and not stall the tractor or shear pins like on the moldboard plows. As far as pulling sideways, they pulled just like moldboard as best I remember. The would cut deep and the 2 pan plows we had we pulled with an 8N Ford. All types of plows, tend to form a hard pan over the years as the limit of the penetration in same year after year. As stated, whatever type of of tillage you use, evey few years, it is necessary to do deep tillage if you want to break the hard pan for deep root growth. Chisel plows and subsoilers will do the trick when the time comes for this, but this might be easier done with a larger machine if the plot is several acres. Most CUT arent going to pull more than 2 subsoilers when you drop them into hardpan at 16-18" deep. I am not even sure that one needs to go that deep for most garden plants and most tillers, disc harrows etc seem to do fine for garden plots.
   / Virgin Ground #19
A multiple point chisel plow set up would be awesome, but takes lots of grunt to pull. Gotta watch out for roots on near "virgin" soil too.
Tillers are great, but doing 7 acres will take lots and lots of fuel and time.
   / Virgin Ground #20
The one we used when I was farming had trips and heavy springs to reset and it did take more power than you would think.
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
Werner 28ft Fiberglass Extension Ladder (A57454)
Werner 28ft...
2021 MacDon FD135 Flex Draper - 35' (A59814)
2021 MacDon FD135...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
5ft Woods 60 Rotary Cutter (A57453)
5ft Woods 60...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
