My recently finish tree scoop bucket
   / My recently finish tree scoop bucket #41
wolc123--What area do you live in and what type of soil do you have?
I live in clay soil now and not sure it would work.
When I lived in gravel-sandy loam of Maine, I very often moved 5-10' evergreens just as the frost left the ground in the spring. I shoved the edge of the bucket in the ground by the tree, wrapped a 3/8" chain around the trunk and lifted with the bucket. I had some damage to the trunk but not much. I just wrapped paper tape around the bruise and it healed in time. Got a better root ball than I did by digging and, surprisingly, less transplant shock.
The clay around here is far less forgiving.
Do you have a phot of your setup?
   / My recently finish tree scoop bucket #42
JJ--
Who made the yellow one?
Can't remember. I saw it awhile back, and I saved it for some new ideas. You can make them any size you want. Just use a cad program and lay it out for cutting, and then have them bend it to the shape you want. You can probably bent 1/4 steel plate by driving over the steel on top of a wood frame. Then take a come-a-long and wrap a chain around and bend it to the shape you want. A plasma cutter or torch can shape one fairly quick.
Some more pic.
   / My recently finish tree scoop bucket #43
I live in upstate NY and have about 36" of dark black topsoil over most of my place with clay under that. Sorry I have never tried to post pictures (not real computer savy), but I just measured and updated the dimensions on my previous post using the "edit" feature. I am always digging the trees out of and into sod, so a wide scoop, or "sides" aint really necessary as quite a big ball always comes out with the scoop. The channel iron I used is mounted flat side up, so the sides are actually on the bottom where they dont help hold any dirt, but do add lots of strength. Like you have experienced, I also get less transport shock using a scoop than hand digging, probably because less roots are disturbed, most of them coming out nice, if the soil moisture is good. I will be keeping an eye on the (2) trees I jumped the gun on last fall to test the scoop however. Clay soils would make things tougher for sure, and a wider scoop with sides would help a lot. One other thing that makes my scoop work well on the 4120 JD, is the heavy front end / 4wd axle on that tractor, which could almost push that 12" wide scoop into cured concrete. The only work involved for me makeing the setup was drilling (3) 9/16" diameter x 3/8" long holes thru the channel, and (1) 9/16" dia x aprox 1/4" long hole thru the bottom center of the bucket. I do have a quick attach bucket but the only time I drop it off is for bush-hogging in the summer. I also have a couple 48" lengths of heavy 4" angle iron that I bolt below the bucket in line with the lift arms for moving and loading logs. These also work very well but required the drilling of (2) additional 9/16" holes thru the bottom of the bucket. Them (3) extra holes thru the bottom of the bucket dont hurt anything, and keeps water from collecting when the tractor is parked out in the rain. I dont do a lot of digging with my bucket so I dont really need a toothbar, but as you can see, I use them toothbar-mounting holes a lot. I also attach clevis hooks here which works better than hooks welded to the top of the bucket because you get more lift using "curl". Someday I may put in another small pond however and when and if I do, I will spring for a toothbar.
   / My recently finish tree scoop bucket #44
Some more pic.
JJ--
I can do lots of things cut cad isn't one if them. My plan is to figure out pretty much what to do by looking at other already engineered items that function correctly.
Then get some starting measurements and take it to a local metal shop that has the correct equipment to roll the steel. I figure 3/8" if they can roll that thick.
Not sure if this is the right idea but it's where I'm at.
   / My recently finish tree scoop bucket #45
Try this. Take some large cardboard and draw and cut the shape until you get it to your satisfaction, and then have the steel mill cut and roll the steel. Then you or a local welder can finish the scoop.
36 in wide bent into a half round will let you get an 36 in in root ball. 42 to 48 long should be deep enough. You push it in deep as you can, using the weight of the tractor. Go to the other side and repeat., and then lift. The tip can be pointed flat or concave. Beveled and sharpened.
Do you have torches and welders?
   / My recently finish tree scoop bucket #46
Yes, have both but live near a small but wonderful welding shop that is fully equipped. Thay have everything, are fairly priced and we like each other.
I like the dimensions you gave and 36 inch rootball, maybe a little bigger would work fine for me.
   / My recently finish tree scoop bucket #47
I need a little help here...should I go with the more pointed tip like the black one in the photo or should I go with the more rounded looking tip like the yellow or red ones? Any thoughts or opinions on this?
The black one is commercially designed so it must(?) be de-bugged but the other ones look like they would work better especially in popping trees out of the groumd.
I took some sketches to the welding shop today and am taking my tractor front loader bracket tomorrow for him to get started. Sure, I could weld this myself but it's 1/2" plate and still winter, here. This is cheap money spent.
I'll post pictures along the way but am having the shovel welded on to a plate and then either having QT loader brackets welded to that plate OR U-bolting the plate to a bracket I have that fits my loader QT brackets.
For now, any thoughts or opinion on the shape of the tip of the shovel itself? More pointed or more rounded on the tip portion ?
Thank you.
   / My recently finish tree scoop bucket #48
I noticed the yellow one does not have a sealed back. You dig stuff out, lift up and dirt will fall out the back.
I use my stump bucket for narrow small hole digging jobs and need to carry dirt around or dump dirt...Even use it to hand mix cement, (using a hoe to get the slurry right), and carrying it to where it needs to be worked.
These stump buckets fill a nitch where a regular bucket would be too wide.
   / My recently finish tree scoop bucket #49
Over the weekend I picked up a stump bucket that I had a local fabricator build. Its base design was the same as pictured below. It was built for my 2007 JD 3120 w/300cx loader. I was so surprised at the ease of operation to transplant a 10' evergreen. Great design and very easy to operate. I have not gotten any pictures. Was to busy moving trees to stop and take pictures.
http://www.tractorbynet.com/forums/attachment.php?attachmentid=200457&stc=1&d=1297724316
Thank you.
The Kubota with the black bucket is my machine. I recommend the slightly flattened tip. This allows the bucket to cut the roots. A sharp tip bucket tends to push the roots to one side or another and not cut. That's my opinion.
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2004 Cherokee Lite 28A 30FT T/A Travel Trailer (A51694)
2004 Cherokee Lite...
2018 DIAMOND C 40 FOOT GOOSENECK (A53843)
2018 DIAMOND C 40...
2018 FORD F-150 (A53843)
2018 FORD F-150...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
Exmark LazerZ Zero Turn Mower (A53117)
Exmark LazerZ Zero...
