Bison
I'm not sure a loose engine mount has anything to do with Perkins not providing warranty on an engine failure. I would tend to think that the loose bolt would fall on the factory's shoulder.
I don't know how many RC/PT100s ASV has built over the years, but I would have to think it would be well over 4-5000 units since they came out in the early 2000s, of which half were probably put into brush cutting. If this is the case, the 20 failures that heavyduty so eagerly points out as failing would amount to a 0.8-1% failure rate; hardly an amount that consitutes an engine problem. That's assuming that all 20 units that he speaks of actually failed due to a defect. I may not be in the mulching business, but I sold over 1,000 machines in my career with Bobcat, and I think we can all agree that not all customers prescribe to the same level of preventive maintenance on their machines. In fact, many of them don't do much maintenance at all. JMHO
I can second to that.
The machine i bought was "meticulously" maintained by the PO.
His maintenance meant in the end "fix only when broke" and "grease only the part that was just replaced".
My fault
Next time ,no records,no sale
