What to use in Ballast box
   / What to use in Ballast box #41
Washed stone 1/2" - 3/4". Filled in the summer (Fork Lift and FEL work), 1/2 to 2/3 thirds taken out for winter snow plowing (front blade). I always leave room for tow chains and whatnot so I never fill it to the top.
   / What to use in Ballast box #42
Obviously the amount of ballast depends on the size and capacity of the tractor and the chore at hand. My Kubota ballast box is handy in close work on the BX2660 with the pallet forks or the FEL. I just throw in a bunch of hedge logs and that's been sufficient for lifting dirt and rock without filled tires or wheel weights. However, I leave the RB on if there's plenty of room.
Looks like my uncle is going to give me a ballast box off his BX for free. I will just have to give it a nice Deere green paint job.:D
   / What to use in Ballast box #44
Fit it up to your tractor before painting. Some of those Kubota boxes aren't cubical and don't fit the draft arms too well.
I hope it does work for you though!
   / What to use in Ballast box #45
Painting might not help, put it on for a week or so and watch closely for signs of rejection.:laughing:
Yah he did say it was not square, something like 24" by 10" and whatever deep... Hopefully it will fit :confused3: as it will save me $250 buck.
   / What to use in Ballast box #47
If its feelings are hurt, do you suppose it would turn "blue":laughing:
James K0UA
   / What to use in Ballast box #48
I use wheel weights obtained from a couple gas stations. Put 4 2inch pvc pipes in each corner to carry hand shovels, rakes, etc
Put a two inch hitch on the back to tow BB, trailer,etc.
   / What to use in Ballast box #50
Double what Roy said! My Kubota box wouldn't fit with the EZ-Hitch on without making some modifications ...even on my BX Kubota. Wish I could post pictures. It does fit, as is, directly to the lower arms however.
Year: 2015 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2015 Make...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2022 Behnke Trailer (A55973)
2022 Behnke...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2023 RTVXG-850 SideKick (A56435)
2023 RTVXG-850...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
