Iseki TS1910 or TS1610 owners?
   / Iseki TS1910 or TS1610 owners? #41
I was needin a radiator,seat, oil filter and belts.Where the best place to shop for these items.
   / Iseki TS1910 or TS1610 owners? #42
It might seem far away but with todays courriers it should also work.
you can try [ M I C R O T R A C T O R S ]
They do have a lot of experience with export so shipping should not be a problem.
Spares are on stock most of the time.
   / Iseki TS1910 or TS1610 owners? #43
I have a couple TS1610 parts tractors & can also supply some new parts.
   / Iseki TS1910 or TS1610 owners? #44
I have a Bolens G192 which is essentially a Iseki TS1910T and it has been great, I don't use it often but it is always ready to work for me.
   / Iseki TS1910 or TS1610 owners? #45
Things like 2-spd. PTO vs 4-spd.,
i have recently bought a TS 1919, it has a selector for a 4 speed PTO but I can only select 2 of the speeds, (marked 2 and -4) the other 2 positions are totally solid, impossible to move the lever into either position, any ideas
   / Iseki TS1910 or TS1610 owners? #46
You might check your linkage it could be as simple as giving it a good soaking with PB blaster or posible adjustment or something could be jamming them like a rock or wasp nest . You will probablly need to remove the left rear wheel & a metal cover to gain access if its like my TA 250 .
First pic is the location of the linkage arms , last two are of the inside of the gearbox where you can see the arms & forks if its more serious . Hope that helps .Good luck ;)
   / Iseki TS1910 or TS1610 owners? #47
Just trolling for owners of the following Iseki tractors...
TS 1610 2WD
TS 1910 2WD
Anybody?
Rick
ten years on, yes, we have both models in 2 wd! looking at another, which is how i came across this post!
   / Iseki TS1910 or TS1610 owners? #48
We are an Owners of and Iseki TS1610 Tractor. We have a few questions.
Where are the Fill and Drain locations for the Hydraulic Reservoir, Transmission Gear Box, and Rear Axle ?
Also, what types/weight of lubricant do each take ?
Are there any filters required for these items and Where are they located?
   / Iseki TS1910 or TS1610 owners? #49
I see that your posts is over 5 years old but if you are still on here do you have a hood for a TS1610?
   / Iseki TS1910 or TS1610 owners? #50
I have a TS1910 and am also wanting to know some basics. Please let me know If you find out the answer to your question.
2019 John Deere 8295R MFWD Tractor (A53485)
2019 John Deere...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
King Kutter TG72...
