Name this JD disc
   / Name this JD disc #1
clee4020
Mississippi
Kubota M9540 HD 4x4
I am re-working my father-in-law's old JD disc that I recently acquired, but don't know the exact model. I found a JD KBA 12' (1st attached pic) on the internet that is real similar, but this one is a 14'. I am pretty sure that many of the KB, KC, KBA, KBL, and KBY parts are interchangeable, but I still want to know model of this disc. I couldn't make out any model # on the disc. Any suggestions?
   / Name this JD disc
It is also similar to RW and RWA models.
   / Name this JD disc #3
The pic looks like a RW to me. I have a lot of Used parts for the RW series. Ken Sweet
   / Name this JD disc
Where would I look for a model? On the tongue? What is the purpose of the chain a pulley near the rear? I thought it was to aid in lifting the back of the disc, but when lifted the chain is not much tighter than when disc blades are on the ground.
   / Name this JD disc #5
There is usually a RW stamped on the end of the frame of the gang. Ken Sweet
   / Name this JD disc #7
It's a John Deere AW. Here is a manual on ebay.
JOHN DEERE OPERATORS MANUAL AW DISK HARROW - eBay (item 170606692198 end time Feb-28-11 09:33:43 PST)
You can also go to the John Deere website and look at the parts diagram.
If his disc is like the one in good first pic in the OP. It is not a AW, I have a AW and they are on roller bearings and have flex built inti the frame work with limiting chains and pulleys. The RW's are on Cast Box bearings usually and are all rigid framed. Ken Sweet
   / Name this JD disc #9
You guys are nuts. That is obviously Fred!
   / Name this JD disc #10
I got to a computer with better reolution and the 3rd picture on the top set is a AW. Ken Sweet
   / Name this JD disc
Thanks, after looking at pics of an AW, I believe that is what I have.
   / Name this JD disc
Found AW on the side of the disc. Still not sure exactly the reason for the chains and pulleys.
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
PALLET OF FILING CABINETS (A60432)
PALLET OF FILING...
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
