6.0L vs. 8.1L in a Chevy truck
   / 6.0L vs. 8.1L in a Chevy truck #21
Diamondpilot said:
454 was a 7.4L. 496 is a 8.1L. I do not remember seeing a 454 or 496 with a 6 speed, just a 5 speed and only the 8.1L was available with the Allison as a option if I remember right????
Chris
The 8.1L was available with the 6 speed Allison in 2006. A friend has a 2001 2500hd RCLB with 220,000 miles on it. He gets 10 mpg towing and unloaded. It has burned 1 quart of oil every 3000 miles since new. I have heard that changing to a 165 degree thermostat will stop most of the oil consumption.
   / 6.0L vs. 8.1L in a Chevy truck #22
That is probably right. I think that was the last year for the 8.1L. That was the first year the Dmax also got a 6 speed. 05's and before like the one I had were a 5 speed.
Chris
Well, as it turns out, the 8.1 turned out to be a much better deal and a better truck in other aspects, so I bought it today. :thumbsup: This was not meant to "dis" the advice here! Thank you again to everyone for the opinions. Picture below:
   / 6.0L vs. 8.1L in a Chevy truck #24
Congrats! You certainly bought a stump puller. :thumbsup:
Now please change those clear "altezza" brake lights. :D
Ha! When I bought my Tahoe three years ago, it had the same nonsense. It also had one of those brushed aluminum gas doors. :rolleyes: I quickly managed to find someone on Craig's List who wanted to swap tail lights, fortunately, and I found a gas cap door at a junk yard that matched well enough.
The tail lights don't bother me quite as much on this truck, but they're still definitely not my thing. Factory look is fine.
   / 6.0L vs. 8.1L in a Chevy truck #26
You may want to look at your truck's service history to see if the transfer case pump upgrade has been performed.
The 01-07 GM HD trucks have a design problem with the fit of the transfer case pump that usually rears it's head between 70K and 130K miles. There are multiple upgrade options available that cost between $40 and $150. If you do the upgrade yourself, you can save around 4 hours labor costs.
Here is a link to more info on the subject.
http://www.dieselplace.com/forum/showthread.php?t=409915
   / 6.0L vs. 8.1L in a Chevy truck #27
Congrats! That's a good looking truck, and that 8.1 is a beast of a gas engine.
Thank you for that info HHR.
And thanks Baucom. It's more truck than I need, but I suppose that beats not enough. I think I'll be spending more time driving my wife's Envoy now though!
   / 6.0L vs. 8.1L in a Chevy truck #29
I'd doubt it. Once you mash the pedal in that 8.1L, you'll wonder why you ever consider any other gas powered truck. :thumbsup:
Somewhere along the way in aging only 35 years, I somehow became an old man and drive as such. I'll probably have the slowest 340HP on the road. :D
300 GALLON FUEL TANK (A58375)
300 GALLON FUEL...
2017 Ford F-750 Crew Cab Terex Hi-Ranger 6TC-65 65ft Insulated Bucket Truck (A56858)
2017 Ford F-750...
(APPROX. 20) 4' X...
Bush Hog RDTH84 (A57148)
Bush Hog RDTH84...
INSPECTION (A57453)
INSPECTION (A57453)
2013 FORD F-350 CAB & CHASSIS (NO KEY) (A58214)
2013 FORD F-350...
