Is this the typical BX front axle leak?
   / Is this the typical BX front axle leak? #1
magnatic
Southern Ontario
2006 BX2350
I noticed this leak on my BX2350. Then I did a search on the forum and found that others have experienced a front axle leak as well. Is it often in the same place?
I noticed that some indicated that switching to 80W gear oil may stop the leak, but I'd still prefer to change the seal and then switch the oil if that's what is recommended.
   / Is this the typical BX front axle leak? #2
That is what mine looks like.
   / Is this the typical BX front axle leak? #4
ya they are all the same i change both of them under warenty was lucky
   / Is this the typical BX front axle leak? #5
i have the exact same problem
   / Is this the typical BX front axle leak? #6
Switching to 80W90 should stop the leak. SUDT is some mighty thin stuff.
   / Is this the typical BX front axle leak? #7
be carefull washing it, what comes out can go in....
   / Is this the typical BX front axle leak? #9
Thanks I will do just that!!
   / Is this the typical BX front axle leak? #10
I was surprised to find out the front axle of my L3800 had SUDT in it.
I'll be replacing with 80W90 when I change it.
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
Electric Sweeper W/Pressure Washer, Water Hose, & Mister (New/Unused) (A59225)
Electric Sweeper...
LOT: Welding Power Leads, 220V Electrical Cord (A59076)
LOT: Welding Power...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
