mickish
Member
- Joined
- Feb 28, 2010
- Messages
- 46
Anyone used 4x6 pressure treated posts to build their barn as opposed to 6x6 posts.
Yep, lots of people do it.
But how tall you make the building is the determining factor. If you only plan on a 8-10' ceiling, then 4x6's on the walls with 6x6's in the corners will be pleanty strong.
When you start getting above 12' walls is when 6x6's are worth the extra cost.
And you may want to check the codes where you live if any of them apply. They will probabally at least specify minimums for a given height.
But me personally, I used electric poles in the 8"-12" diameter range for my 14' high walls.
I think I need at least 10 ft ceiling height at least,other wise what's the point,I'm thinking 12ft ceiling height would be best so as I get 10 ft door height ,so maybe 6x6 is the way to go.I was thinking the osb sheathing would add some as well as wire lath would add some strength .the cost difference between 4x6 and 6x6 is a fair bit.
24x40 with a loft,if I go over a thousand sq ft I have to do storm water management and I ain't sure what all that will entail so I'd rather avoid that secnario.
Randy, Just curious, are the posts nailed together or glued? Also, did the rafters with cross ties come in one piece or did they put them together in place? Morton builds a nice barn.Morton built our stables 48'X36'X10'. They build their posts by laminating 3 2X6 so there is not any warping. They are on 12' centers.
Nice write up and I have the same thinking. I will also add, the so called foundation (posts) is not the place to try and save money.FWIW, I'm partial to the laminated 2x6 (3plys). If you are burrying the post directly in the ground and not using the new Permacolumn concrete type base for your posts. Three 2x6 are better protected with what ever the chemical du jour is now (I like and trust the old CCA) for treating wood, prolly ACQ whitch will eat your fasteners in short order!!! A 6x6 is only penetrated an inch or so (with preservative) where the 2x6 is pretty well treated all the way thru, it should last longer. A couple of other reasons are, try to find a straight 6x6 over 10' and a 3ply 2x6 is stronger and will stay tru.
Lately the pre manufactured posts have been very popular and nice to use. Don't know if they are avail. in your area but they finger joint and glue them together with 3 2x6 and the lower 6-8' or so is PT and then KD above that for the rest of the post. They then send it thru a planer and smooth it out, it is a very nice product, and I found the convience and appearance of them made them affordable.
And by the way I think you asked, when I laminate the posts, I just clamp and (oposing) angle nail the sheet out of them usually, but the last posts I built I splurged on these new hi tech screws with a built in washer head. Very nice, very strong, and can be tightened if you want when you have shrinkage.
One more thing, do your self a favor and go with 12' ceiling, a few more bucks for side wall metal but, well worth it.
Sorry to hi-jack the thread but I want to take the oppourtunity to point something out that might be of interest.The trusses were built at the Morton factory. Two 18 wheelers showed up and offloaded the materials and the trusses were already built. The posts were built onsite, glued and nailed. If you zoom in on the left post in the second picture you can see how they cut the center 2X6 short and place the truss in the notch. They then bolted the truss to the outside members. The 2 2X6 inverted Ts between rafters is how I mounted my 8' flourescent lights.
