Shop tools you wish you had
   / Shop tools you wish you had #21
Welder, table saw, miter saw, drill press, just to name a few...(I'm sure I'll think of more)
   / Shop tools you wish you had #23
Good torch, plasma cutter, another large building (it's not a tool but if a guy's gonna wish, he might as well include a new building), a larger capacity welder, milling machines and a lathe, a large press, a larger compressor, sand blaster, a good band saw
   / Shop tools you wish you had #24
For ever I wanted an Ironworker, thanks to craigslist I now have an Edwards 50 ton!!! Yeah!! Next on the dream list is either a cold saw or a tubing bender, I think in that order.
For you guys dreaming of a Plas. cutter, I don't think that they are worth it, just like with a torch, to get that grind free ready to assemble edge you still need to "fence" your cuts and watch your speed. It has it's place but other than cutting alum, to me, it's an expensive electric torch.
   / Shop tools you wish you had #25
Heated pole building. That's a tool isn't it?
   / Shop tools you wish you had #26
Just looked up an Ironworker. I'd never seen one before. On my wish list now.
   / Shop tools you wish you had #27
Isn't this the biggest problem of having all of what you want.......the rent/mortage/taxes/utilities of the structure to contain it all will consume you in the end........Oh but what a place to work.......:thumbsup:
   / Shop tools you wish you had #28
Top of my list would have to be a big drill press that is capable of going down to less then 200 rpm. 140 to 160 is where I really want to be.
Next might be a Mig Welder
Eddie
Eddie,
Just buy a bridgeport type mill and be done with it......your drill press won't ever get used.....;)
   / Shop tools you wish you had #29
I'd like to have a good big finger break. Something that would handle 4 feet of sixteen gauge steel at least.
   / Shop tools you wish you had #30
A Bridgeport, metal lathe, surface grinder. Problem I see, is by the time I can afford things, I don't need them as much. With the price of metal being pretty high, metalworking projects usually aren't practical.
2005 John Deere L118 Automatic 42in Riding Mower (A51694)
2005 John Deere...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53473)
2012 KINZE FLAT...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
Rock wood travel trailer (A51694)
Rock wood travel...
GENERAL ELECTRIC HOE WASHER & DRYER (A51248)
GENERAL ELECTRIC...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
