Too big for the mill...
   / Too big for the mill... #1
Lloyd_E
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
We have been collecting logs from around the neighbourhood - semi-urban logging...
This is the biggest to date - about 36" at the butt. The mill will only handle 26" max. We will probably trim with a chainsaw and finnish on the mill. There appears to be a little rot in the centre...
   / Too big for the mill... #2
What kind of tree is that? The butt looks nice, but that top is rather ugly. I'd be tempted to cut the top back to 1 stem, then saw backwards to pare it down to fit on the deck. Yet you know what your mill can do.
Have fun.
It's a pine and we are thinking the same thing... have't completed a ring count yet.
   / Too big for the mill... #4
I know a few sawyers that wouldn't touch logs like that. Trees from an urban setting are likely to contain nails and other foreign material that is hard on saw blades.
   / Too big for the mill... #5
Nails, clothesline pulleys, other "unique" things... I went on one mill tour that the sawyer told about hitting an electrical insulator that was like an explosion.
   / Too big for the mill... #6
You list enough equipment to support it... do you mind if I ask what you have for a mill?
   / Too big for the mill... #7
You could drive the chainsaw blade in it few times, fill it with black powder and split it with the explosion - bang! and ready for the sawmill:thumbsup:
   / Too big for the mill... #8
I was thinking about a pine in my back yard this morning, that was too big for the cutter (shear) to handle, and nowhere to drop it with a saw (buildings), so they left it 10 years ago. Might need to find somebody that can cut it up before I drop it, so it doesn't go to waste.
David from jax
   / Too big for the mill... #9
I know a fellow, who looks like he fell off a mountain, that has a been sawing for years with a band mill. He does the big logs like you said, some saw kerfs, some gun powder, a little cannon fuse and some mud to seal the kerf. I have an LT 30 band mill, but I have not felt the urge to try that procedure myself, but it does work.
   / Too big for the mill... #10
Dang, that's a big one!! I'm thinking coffee tables or a he## of a bench....
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2008 Dodge Ram 1500 (A50515)
2008 Dodge Ram...
Backhoe Attachment (A50322)
Backhoe Attachment...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Case IH Farmall 75C (A52349)
Case IH Farmall...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
