Too big for the mill...
   / Too big for the mill... #1
Lloyd_E
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
We have been collecting logs from around the neighbourhood - semi-urban logging...
This is the biggest to date - about 36" at the butt. The mill will only handle 26" max. We will probably trim with a chainsaw and finnish on the mill. There appears to be a little rot in the centre...
   / Too big for the mill... #2
What kind of tree is that? The butt looks nice, but that top is rather ugly. I'd be tempted to cut the top back to 1 stem, then saw backwards to pare it down to fit on the deck. Yet you know what your mill can do.
Have fun.
It's a pine and we are thinking the same thing... have't completed a ring count yet.
   / Too big for the mill... #4
I know a few sawyers that wouldn't touch logs like that. Trees from an urban setting are likely to contain nails and other foreign material that is hard on saw blades.
   / Too big for the mill... #5
Nails, clothesline pulleys, other "unique" things... I went on one mill tour that the sawyer told about hitting an electrical insulator that was like an explosion.
   / Too big for the mill... #6
You list enough equipment to support it... do you mind if I ask what you have for a mill?
   / Too big for the mill... #7
You could drive the chainsaw blade in it few times, fill it with black powder and split it with the explosion - bang! and ready for the sawmill:thumbsup:
   / Too big for the mill... #8
I was thinking about a pine in my back yard this morning, that was too big for the cutter (shear) to handle, and nowhere to drop it with a saw (buildings), so they left it 10 years ago. Might need to find somebody that can cut it up before I drop it, so it doesn't go to waste.
David from jax
   / Too big for the mill... #9
I know a fellow, who looks like he fell off a mountain, that has a been sawing for years with a band mill. He does the big logs like you said, some saw kerfs, some gun powder, a little cannon fuse and some mud to seal the kerf. I have an LT 30 band mill, but I have not felt the urge to try that procedure myself, but it does work.
   / Too big for the mill... #10
Dang, that's a big one!! I'm thinking coffee tables or a he## of a bench....
Champion C80 B (A50322)
Champion C80 B...
INGERSOLL RAND 175 PORTABLE AIR COMPRESSOR (A51244)
INGERSOLL RAND 175...
KUBOTA M7060 TRACTOR (A51243)
KUBOTA M7060...
2018 CATERPILLAR 305E2CR EXCAVATOR (A51242)
2018 CATERPILLAR...
6-Row Rolling Cultivator Narrow INOPERABLE/PARTS ONLY (A52128)
6-Row Rolling...
TRAILER AXLE (A51244)
