Hitch pin size
   / Hitch pin size #1
Rathpr
Member
I have an attachmnet with holes in the tongue of 3/4-inch. The drawbar has a hole of 1 1/4 -inch. If I get a 3/4-inch hitch pin it seems like this isn't going to pull smoothly when I stop and go. Is there any way to get this to fit better? Thanks.
   / Hitch pin size #2
Without making a busing from scratch, look around for a short piece of 3/4 thick wall pipe that you can cut to length to act as a bushing. I used 3/4 sch 40 pvc to act as a bushing for a 1" dia. hole. I had to cut a kerf in the bushing so it would colaspe slightly but it works fine, even on heavy pulling.
   / Hitch pin size #3
Have done exactly this for a ball hitch on my truck for light-duty short-term fix.
Bruce
   / Hitch pin size
thanks for the info. I'll give it a try
   / Hitch pin size #5
If the hole is 1 1/4" I'm guessing you have a pretty thick drawbar. A rule of thumb is the thicker the drawbar, the looser the pin fit on solid equipment hitches (some big equipment have hinged tongue ends). The reason is if you pull something through a ditch for instance, the hitch is swinging up and down and the pin needs room to change angles or else the hitch will pry against the pin until something gives. I would stick with the 3/4" pin that your equipment was designed for. Tractor pulled equipment usually work fine with some slop.
   / Hitch pin size #6
Always use the largest pin possible within reason. Hitch flexing will always be present and the pin shouldn't bind. If the implement is only used occasionally a smaller pin should be fine. Excess play is more apparent on very large farm implements, which will also affect handling when driven on the road. A large 1000 bushel grain cart is a good example where a tight pin is necessary.
   / Hitch pin size #7
I'm not in agreement with the "hitch movement" concept either. Use the right sized pin for the smaller hole, then use bushings to make up the difference in the larger hole
//greg//
   / Hitch pin size #8
//greg//
Good way to bend or shear the pin.
larry
   / Hitch pin size #9
How Larry? If the pin is not allowed any movement off vertical, it's a straight pull. Using the right sized pin for the hole - or using the correct reducer bushing to properly adapt a pin to an oversized hole - keeps the pin 100% vertical in relation to the hitch. It's when a small pin is being jerked around in a big hole that shearing/bending forces come into play
//greg//
   / Hitch pin size #10
Something has to give if traveling over very uneven ground, through dips or across roads, etc. Up and down angle differences in the hitch are easily handled by loose fitting pins, not tight ones.
But a fairly smal pin can still handle a strong pull.
On the highway, close tolerances are much more important than at slow tractor speeds in the field.
   / Hitch pin size #11
Do like Snaker says. If you bush the hole down, you will bend or break the trailer hitch and/or pin. The hitch pin has to have some space for movement unless you install a swivel eye or change it over to a trailer ball and hitch.
   / Hitch pin size #12
That full 1/2" of slop - at a minimum - is going to eventually cause the comparatively lighter duty 3/4" holes to enlarge (egg out).
If the attachment has a hinge (or device) that permits vertical movement of the tongue, it should dispel any concerns about pin damage due to towing over uneven ground. In that case use a bushings or sleeves to take the 1-1/4" tractor hole down small enough to accept the 3/4" pin.
If the attachment has a rigid tongue, use your best judgment as to how much bushing/sleeve - if any - you want in the 1-1/4" hole. I support the earlier suggestion about using a short piece of 1" ID steel pipe. That will take the hole down to about 1", and still leave the "wiggle room" that some of these other guys are concerned about.
FWIW, I'm on 30 acres of rough pasture and steep wooded hillsides, over which I've towed a reasonable cross-section of attachments behind six different Cat 1 and Cat 2 tractors. After doing this for 16 years, I've probably accumulated five pounds of assorted bushings and sleeves. In all that time I've never once incurred any kind of damage to a pin, a hole, a bushing, or a coupler.
//greg//
   / Hitch pin size #13
//greg//
I suppose a smaller pin could wear out the drawbar hole faster but your losing me about the hitch wear (3/4" pin in 3/4" holes). I guess I should have been a little more through with my comment. #1 priority is to have a pin capable of handling the load. When you have a pivoting hitch tongue end (end towards the tractor) you can stuff the holes as tight as you want with no problems. If the tongue does not pivot, then you need room at the hitch pin to allow for flexing. The amount of room needed is amplified as the drawbar thickness is increased. Smaller tractors with 1/2" thick drawbars are less of an issue.
Say for example that you bushed the drawbar hole to 3/4". Now you have 3/4" holes and pin. If you were to take a 4' hitch pole off a wagon and attach to the drawbar you would get maybe 6" of vertical movement at the rear end (assuming unworn holes). That pole can easily see 3' of vertical movement in relation to the drawbar. Remember that the drawbar attitude changes also as the tractor goes nose up/down. There is going to be a problem is the hitch has to move 3' but is only allowed 6".
I have seen a empty gravity box wagon with the front wheels off the ground due solely to no pin clearance. In that case a drawbar maybe 1.5" - 1.75" thick with a worn hole was "fixed" and given a 3/4" hole because "all the pins are 3/4"
As far as the connection for road hauling, thats a tough one. I've never pulled jumbo wagons. What pin size do they run, maybe 1"? Hard to argue for a sloppy connection, but if a wagon is wandering all over the road, I would bet it has more to do with bad wheel toe and worn steering on the running gear than a 1/4" of slop at the pin.
   / Hitch pin size #14
I have seen a empty gravity box wagon with the front wheels off the ground due solely to no pin clearance. In that case a drawbar maybe 1.5" - 1.75" thick with a worn hole was "fixed" and given a 3/4" hole because "all the pins are 3/4" As far as the connection for road hauling, thats a tough one. I've never pulled jumbo wagons. What pin size do they run, maybe 1"? Hard to argue for a sloppy connection, but if a wagon is wandering all over the road, I would bet it has more to do with bad wheel toe and worn steering on the running gear than a 1/4" of slop at the pin.
Exactly. I just dealt with this last weekend as I built a drawbar and hitch system for a farm utility trailer. Instead of making it tight and having to build an extra pivot for the vertical tongue movement, I left it loose enough to accommodate the uneven ground, hills, etc. Simple. Effective. And fine for low speed utility work around the place. When I want a bigger pin in the larger tractor's draw bar I sometimes use a piece of 3/4" pipe. Works fine by itself.
   / Hitch pin size #15
I gotta say, I have hauled a lot of hay with a 3/4" pin through a 1 1/4" hole 4 to 5 tons to the wagon, I have never sheared a pin. If you don't want any play, covert to ball and coupler hitch's. The pin doesn't cause a wagon to wander, the tie rod ends do. I have a feed wagon with a ball hitch and it wanders all over the road. These things aren't made like your truck and utility trailer, they need the slop to function properly.
Just my 2 cents.
   / Hitch pin size #16
I would pin the implement with the 3/4" pin and not look back, not worth worrying about.
   / Hitch pin size #17
Some of you guys are over-thinking this. A draw bar and and hitch/tongue setup is meant to be a loose fitting system. After the OP cuts off a few finger tips trying to put the bushing in the draw bar he will wonder if it was worth it.
Yes the holes will elongate very minutely over time, but not enough to create a problem.
I have never seen teeth on a wagon tongue, but I know they can bite if given the chance.
   / Hitch pin size #18
I personally would not worry about it. I see farmers around here with screw drives, tire irons, bolts, rebarb, ect being used as hitch pins. If you want to fix it for good just drill out your implements to match the draw bars pin hole size then use that larger size pin.
Chris
   / Hitch pin size #19
Bingo. Does anyone think that farmers are carrying around bushings for every thing they hook up to the draw bar? No. These things are sized the way they are for a reason.
   / Hitch pin size #20
if the pin is close to the size of the hole (tight) in both sides of the hitch junction something has to give when working on uneven terrain, it will either be the pin bending/breaking, or the drawbar/tongue bending.
if you absolutely have to use a sleeve find a barrel shaped one. that way all the slop is taken out in the horizontal plane and still allow movement between the drawbar and tongue for uneven terrain.
UNUSED FUTURE 90-PLATE COMPACTOR (A60432)
UNUSED FUTURE...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
YANMAR VIO17 EXCAVATOR (A60429)
YANMAR VIO17...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
