Gardening help
   / Gardening help #1
hizoot
Gold Member
Flint Texas
jd 2520
This will be the first year we will be taking on a garden of much size.(1/3 acre) It will also be the first for planting different vegetables for the first time..such as potatoes,asparagus,watermelon,and cantaloupe to name a few. Is there a website that may help us with some basic knowledge in setup,care,irrigation,timing,etc?
Also, I would like to make the beds mounded rows....I do not see an implement around our immediate area being sold that does this. So...can I take a cultivator,remove some tines, install a couple of discs mounted almost 90 degrees to the direction of travel to do this? What would be a good row spacing?
....as you can see,we need some input! Thanks!
BTW, I have a new JD 2520, 60" tiller, box blade ...if that helps with input. I can weld...and wouldnt mind making my own "hiller",and can copy a design or picture if its cost effective.
thanks...
   / Gardening help #2
I think your best bet for gardening info will be Texas A&M.
Home Vegetable Gardening | Aggie Horticulture
I seem to recall several threads dealing with build-your-own hillers/hippers/bedders. You could try searching for those threads if someone with direct experience doesn't respond.
Good luck with your garden.
Steve
   / Gardening help #3
Steve gave you a good link, I have used it for years. Here is a link to their main page.
Aggie Horticulture
You should also go to your local County Extension agents office, they should have brochures with great detail on almost everything "rural" in Texas.
I usually go 36", shorter for some, really depends on what your growing in the row. large plants such as Corn, Okra I will go 36", smaller ones like radish, carrots I go smaller.
Melons are even further spaced.
As far as the rows, try your idea, should work if you don't mind the down time.
Texas A&M and your extension agent will get you going well for your area.
   / Gardening help #4
To go along with what everyone has said about the TAMU site. They maintain Master Gardener websites for locations around the state. The local website for your area is Smith County Master Gardeners. They will probably have the best info for your area and charts showing planting dates that work best for various crops. They are a huge source of info.
Here is Home Vegetable Garden Guide PDF file from the TAMU site. It shows average last frost date info for your area as March 1st. You are safe to plant anything right now.
   / Gardening help #5
I suggest also reading the book "Joy of Gardening" by Dick Raymond. Lots of great info.
   / Gardening help #6
thanks...
Something like this perhaps? Won't eat much, and takes up little space in the barn/garage. I'm sure we can both agree on a mutually beneficial design cost reimbursement. :D HTH, Mark
   / Gardening help #7
I built one very similar to this and it works great at hilling.
My plan is to use for potatoes this year and then swap out to a shovel for digging them. Should work fine.
   / Gardening help #8
I did my raised rows by putting 2 big 20" discs at 45 degree angles right behind the rear tires. Pounted the discs on an old soil ripper diamond bar. You can get a similar rig from Agri Supply called a Keulavator. You can also order the discs and clamps there.
Here's a photo of mine.
1/3 of an acre is an awful big garden. I have a 50x75 one that feeds lots of people. Made 20 rows in it.
Ralph
   / Gardening help #9
RalphVa,
I need some diamond toolbar mounting clamps to add some cultivator sweeps or other tools onto my toolbar. Do you know of a source? I would prefer those like near the middle of your toolbar which appear to be cast steel. Any workable style would be helpful though. Thanks for your help.
Arkaybee
   / Gardening help #10
RalphVa,
Arkaybee
"Market Implement" or something like that in PA sells a variety but are sort-of costly.
I used some clamps off a 1970's Ford cultivator. Others similar.
Photo when I can get back in the barn or sooner if needed.
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
2015 Chevy Cruze Sedan (A56859)
2015 Chevy Cruze...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
SKID STEER ATTACHMENT BRUSH WITH BOX (A58214)
SKID STEER...
