Do You Remove TnT for Some Impliments ?
   / Do You Remove TnT for Some Impliments ? #11
I put my top n tilt kit on my 4520 the day after I brought it home in 2009 and haven't taken it off since then. I have a planetary auger so I can't think of a reason to need it removed.
   / Do You Remove TnT for Some Impliments ? #13
   / Do You Remove TnT for Some Impliments ? #16
I haven't talked to them yet but I was thinking they would be my first try. I'm looking at the 2" cat1 cylinder with the 21" to 32" range for the top link and don't know about the side link - need to see what they have. I'm trying to get educated so comments are welcome. Thanks
gg
Based on my personal experience, I would never buy from CCM again. I've read all about the wonderful experiences other posters have had with this company but my HTL from CCM leaked after installation. I took the fittings sent with the unit to my local hydraulics supplier and his opinion was that they were the incorrect fittings. He called CCM, spoke with Mark who told him to sell me the correct fittings and that if I sent the receipt to CCM, they'd cover the cost. He did, I did and CCM didn't. I'm not upset about the leaky fittings or the extra $17 I spent but rather the broken promise. For a savings of $17 CCM lost this customer for life. What kind of business model is that?
Seems like that is the worst thing a business can do. If they try hard and do there best and do what they say they are going to do, then everybody respects that. If they don't They can't expect repeat business.
Thanks for the heads up
gg
   / Do You Remove TnT for Some Impliments ? #18
gg
Gordon, I don't think you will have to search very far to find there are plenty of folks who have had issues with Surplus Center also. I'm sorry flowerfarmer has had a bad experience, but even he admits that most have been very happy with Mark and CCM's service. CCM sells the toplinks and also can provide you with a hose and fittings kit for a seamless turnkey operation. With Surplus Center, I believe you are left to figure that out on your own. Buy from whomever you choose. Just be aware that there are things CCM will do for you that Surplus Center does not do.:)
   / Do You Remove TnT for Some Impliments ? #19
I've had my TnT for 3 years now. It's been a great advantage for many different jobs. However, there are 2 attachments that do not co-exist very well with the system on my JD 110.
My Kuhn disc mower does not work real well with the tilt cylinder installed. The variable changes to the tilt creates havoc with the cutter bar angle and will result in an uneven cut and/or the cutter digging into the ground. So, I drop the tilt cylinder and use the hard link whenever I'm using the disc mower.
Another attachment that I've discovered problems with is my hay rake. It's a Kuhn (think there's something with Kuhn..) rotary rake and the length of the frame will result in the top cylinder smashing into the mounting bracket that holds the top cylinder up when not in use. The bracket has a pin that fits into the cylinder to keep the cylinder from flopping and banging when it's not attached to an implement.
The cylinder diameter does not allow for enough clearance when I lift the rake off the ground. I have to be very careful to not lift the rake very high off the ground or I have to use the hard-shaft top link when using the rake.
Long story - short: you do have to pay attention to whatever attachment that you plan to use with your TnT. You can have conflicts with the cylinders.
AKfish
AKfish
Is this because your top link cylinder drifts or doesn't hold or is there something else about it I need to understand ? If it is a drift problem how long will it hold before you have trouble ?
Thanks for the input.
2017 JEEP CHEROKEE (A53843)
2017 JEEP CHEROKEE...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
SDLANCH ELECTRIC GOLF CART (A53843)
SDLANCH ELECTRIC...
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
1999 TRAILMOBILE DRYVAN (A53843)
1999 TRAILMOBILE...
