2320 hydro drive shaft just snapped off !!!
   / 2320 hydro drive shaft just snapped off !!! #51
Boy...this is just fun....learn something new everyday. :confused2:
If this is your idea of fun.........well let's just say, count me out......:eek:
   / 2320 hydro drive shaft just snapped off !!! #52
Here are a few pictures of the u-joint with the zerk. The pictures are taken directly from underneath the 2305. The manual makes references to all the other grease nipple except those 2 on the engine-hydro drive-shaft. Pita to grease them but it is possible on the 2305 using the needle adapter. I was just lucky to find them the first time I service the tractor. And you guys are right, there are no zerk on the hydro-front drive axle. :confused:
I say "this is fun" while banging my head repeatedly against the wall:mur:
   / 2320 hydro drive shaft just snapped off !!! #54
   / 2320 hydro drive shaft just snapped off !!! #55
As long as it's not a padded wall while wearing a straight-jacket.....:laughing:
   / 2320 hydro drive shaft just snapped off !!! #56
Now this thread has me wondering what hidden grease fittings might I be able to find on my rig! Anybody know if there is more than the ones that I can actually see being front linkage and TPH. My owners manual says that's all there is! :mur:
   / 2320 hydro drive shaft just snapped off !!! #57
25/2720 have 2 under each floorboard (one side may have 3)
Belly mower linkage has one on each side under back axle
   / 2320 hydro drive shaft just snapped off !!! #58
MaJYk could you please expand on this. I would like to know what these grease fittings are for and how to get to them.
Thanks Tim
   / 2320 hydro drive shaft just snapped off !!! #59
1st pic- 2 fittings on right next to the frame for hydro pedal linkage
2nd 3rd 4th pic - left side brake linkage
5th pic - right side facing forward, crossbar attaching point on mmm lift linkage
6th pic - left side facing rear ( same description as 5th pic)
Also, each pivot point on each side of loader.
62D-3 spindles, tensioner, 2 ujoints, pto shaft, 4 gauge wheel axles, front 2 gauge wheel pivots
If u can't find them let me know an I can get better pics
While on this subject, does anybody else have trouble getting the front axle pivot to "take"? My battery gun will bypass before it builds the pressure to get it greased, have to keep grease in the old pump gun just for this one.
   / 2320 hydro drive shaft just snapped off !!! #60
The 2520 does not have ujoints in the driveline to the rear hydro unit like the 2210,2305 and 2320 have...This is the items in question..
2016 Ford F-150 Pickup Truck (A51692)
2016 Ford F-150...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
