Bought my first garden implement
   / Bought my first garden implement #11
   / Bought my first garden implement #12
I got to playing with it today, thought I'd post a couple pics. I also have a question. The lift pins are standard cat 1, but the hole for the top link pin is huge, the head of the pin will fall right through it. Kinda like they drilled it for a cat 2 or 3 pin. Anyone ever run into this? Is there a pin with a large head that won't fall through or will I just have to weld a doubler plate on it with a smaller hole? The spacing is also really wide like it's meant for a bigger top link.
Ian
Love you slow moving vehicle sign.:thumbsup::laughing:
Thanks, bought one of those at TSC today. I'm going to weld a couple pieces of that into the top link connect point (what's the technical name for that?) to fill the slop.
I took my triangle to a sign shop and had them letter it in reflective material. I thought about what I might put on there for a couple weeks... "Mity Mouse" was in the running too, but I had to limit the length of the words if I wanted the letters large enough to be readable from a distance. I'm still not real satisfied with it.
Ian
   / Bought my first garden implement #15
I've been thinking of getting a TSC middle buster too...
If you do, I recommend the orange one. First, of course, it matches better, but beyond that it is shorter, which is a big big plus for traversing the yard.
Truly. Join TSC online and get a $10 coupon or just ask the manager for $10 off. Bet he/she gives it to you.
Mine has plenty of ground clearance when raised, no problems at all. I don't think I'd want it much shorter than it is. I had it deep enough to get dirt on the cross member when I was playing around with it in my garden. :thumbsup:
   / Bought my first garden implement #17
Happy Saint Patrick's Day you potato planters. For years I've hand dug my spuds with a fork. When the kids lived here, we used two forks...one on each side of a plant. Now, by myself, that's a real chore. This Middle Buster (potato plow) sort of mystifies me. Do you straddle the tractor over the row with that plow way down below the taters? Doesn't that tear them up somewhat? Maybe I'll get one and it might even work better that a single bottom mold board for plowing in general. Thanks for sharing your thoughts.
Yes, that's the idea... You straddle the row, the plow goes under the hill and upends it. I'll let you know when I use it for what it's intended for but that may be a few months. :)
   / Bought my first garden implement #19
They're also great for digging drainage ditches and burying pipe/cable.
I have the FarmFarce subsoiler version - with the SS blade it pulls up small stumps nicely..
   / Bought my first garden implement #20
At TSC, two years ago, when I bought mine, they had two different lengths. The yellow one was quite long and the BX I had at the time, would not carry it high enough to traverse the yard with enough clearance to provide comfort.
TSC changes stuff all the time, so who knows today, but something to watch out for if you have a subcut.
Haywire, your's looks to be the yellow, short model.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A52377)
2012 International...
