MaJYk
JDdude said:The 2520 does not have ujoints in the driveline to the rear hydro unit like the 2210,2305 and 2320 have...This is the items in question..
My posts were in re to glen and rogator
1st pic- 2 fittings on right next to the frame for hydro pedal linkage
2nd 3rd 4th pic - left side brake linkage
5th pic - right side facing forward, crossbar attaching point on mmm lift linkage
6th pic - left side facing rear ( same description as 5th pic)
Also, each pivot point on each side of loader.
62D-3 spindles, tensioner, 2 ujoints, pto shaft, 4 gauge wheel axles, front 2 gauge wheel pivots
If u can't find them let me know an I can get better pics
While on this subject, does anybody else have trouble getting the front axle pivot to "take"? My battery gun will bypass before it builds the pressure to get it greased, have to keep grease in the old pump gun just for this one.
I'm not sure from the pics but is this the front shaft that drives the front gearbox on the 4WD?
I ask because I did this when I had my 2320. I was going down the road and it blew. I fixed it myself and my dealer covered the cost of parts which came to about 8 or 9 hundred bucks.
The thing about Deere is that they know drive shafts and splines break and they make the input shafts on gear boxes short so they are easy to replace without ripping apart the whole box. (It took me about two hours to fix mine)
Also Deere has an updated front shaft which is about an inch in diameter as opposed to the old shaft which is about 5/8" in diameter.
Rob
Rob
Rob, the OP'r will end up yanking it all apart on this one since the input housing broke too.......Much bigger fix than just input shaft.....
How many hours on your tractor when your troubles happened..??
Less than 100 hours.
Got it Kenny! My mistake.
This might help though. When my shaft went I found one 'U' joint was binding?
