Pin Holes and Tubing, Drill bits
   / Pin Holes and Tubing, Drill bits #21
I agree with the people recommending hole saws. When I first heard about that method, I didn't think it would work, but now, I'm a believer. So far, I've done up to about 1 1/8 inch holes with a hole saw in the drill press, and they work great. Just be sure and use plenty of oil
For thinner metal, say, up to 1/4 inch and smaller holes, up to about 3/4 diameter, you can also get away with using a step drill.
   / Pin Holes and Tubing, Drill bits #23
Great info - thanks to all who have contributed. I am trying to adapt a set of Sundowner forks to my pin-on LA724 FEL and thought I had painted myself into a corner. Now I see a way out and where to get the stuff to do it. You guys are the best!
-Jim
   / Pin Holes and Tubing, Drill bits #24
Magnetic drills can be purchased used. Mine cost me $75 from a pawn shop because the motor was loose and somebody put a wedge of wood in it to tighten it up (and making it drill really crooked). A friend needed to borrow it, so he tightened it up before using it and it now works great. (That is a +1 for loaning tools to friends and neighbors)
David from jax
   / Pin Holes and Tubing, Drill bits #25
I used silver and deming bits with oil bath from HF to drill my large holes with a drill press. Its not the bext solution, but it works for me. cheap too.
   / Pin Holes and Tubing, Drill bits #26
personally, i have a cnc plasma machine that would do it no problem, but before i had this, i used a simple hole saw. just expect to burn one up per hole, there cheap to buy.
i drilled thru 1/2" plate without an issue.
   / Pin Holes and Tubing, Drill bits #27
Where in CT are you located? If you are close to the Bethel area let me know if I can help out.
I am near storrs.... I Appreciate the offer but I am someone that doesn't like to borrow stuff, if I need it I will buy it so I have it in the future.
I think I am going to buy a MT2 to 3/4" Weldon adapter and get a couple Annular cutters (1" and 1.25") and try using my drill press.
Everything I have read about Annular cutters is positive. Drill presses can cut bigger holes at faster speeds then twist bits. They last a LOOONG time. etc...
   / Pin Holes and Tubing, Drill bits #29
I have a fabricator downstairs, I can usually get just about anything done for Coffee and Pizza if it's big project.
I wish I had a fabricator downstairs...
UNKNOWN 16 T/A TRASH TRAILER (A53843)
UNKNOWN 16 T/A...
JCB 270T T4 SKID STEER (A52705)
JCB 270T T4 SKID...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
1987 CASE IH 9150 TRACTOR (A53843)
1987 CASE IH 9150...
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
PAIR OF VACUUM PUMPS (A53843)
PAIR OF VACUUM...
