Nimco part numbers
   / Nimco part numbers #1
jhwentworth
Loudon, New Hampshire
Agco ST35
I have a leaking o-ring on a Nimco control valve for my Agco ST35 with SL46 FEL. The oil leaks from the joystick base plate when the bucket is curled. The AGCO parts books lists a couple Nimco controls as being used on the SL46: the CV-112, CV-422, and CV-432. MY valve has a plate with the number 2S-40272 and a serial #219029. The base of the valve has 1M-4132-2 stamped in it.
Question: How do I interchange the numbers I have to a Nimco assembly number in the CV-XXX format.
Not exactly. Some of the valves listed on the Agco book, like CV-422, are not listed here.I'm looking for an interchange list that will convert the numbers on the tag to the numbers used on the Nimco site. I gotta tell you, this labeling stinks.
Update: I spoke with Nimco and was told that my valve was in the CV-422 family and 2S-40272 was the Nimco part number, The Nimco rep also said that the part number/family interchange information was not posted on the Internet. It figures that the Nimco valve family missing from the Nimco web site would be the valve that I have.
After taking the valve assembly apart I discovered other things wrong, so I asked my local tractor dealer for a price for a complete replacement unit. The part number is 71515225, and the quote was for $1362. Some checking around yielded a price of $586.50 + shipping. It does seem there's considerable difference in pricing, so check with the Nimco distributors.
I'll still probably go for a repair, but it helps to know that a replacement won't cost over $1300.
   / Nimco part numbers #8
after doing some research I found this out.
I used a caliper to measure the female ports
The side ports are 13/16.
The bottom 4 ports are 11/16.
so from googling around:
-08 SAE #8 3/4-16 3/4" (0.75) 11/16" (0.69)
-10 SAE #10 7/8-14 7/8" (0.88) 13/16" (0.81)
So for us to get the valve we would need a sae male #8 to sae female#10 adapter? for the side ports?? Like the following?
http://www.surpluscenter.com/item.asp?item=9-6410-8-10&catname=hydraulic
All of the line threads have O rings.
   / Nimco part numbers #9
Sounds like you have it figured out TJ.
   / Nimco part numbers #10
Sounds good. I ordered up all the parts 230 bucks.
So I will post for everyone else on how I make out.
I was not spending $1400 at massey dealer for another nimco valve.
2022 John Deere Z930M (A57148)
2022 John Deere...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
CATERPILLAR ARTICULATED WATER TRUCK (A60429)
CATERPILLAR...
