Baltimatic Spreader - Frozen Agitator Pin
   / Baltimatic Spreader - Frozen Agitator Pin #1
FarmerCharlie
Member
Auburn, AL
JD 2130 and 1020
I have been using my Baltimatic 80 spreader for years with no problems. It has an agitator attachment that I used a few times when spreading lime, but have not used lately. When I needed to use it again, I could not get the connector pin (Item 5 in the first image) to swivel up to attach the agitator.
It was frozen to the shaft. I tried prying it and soaked it in WD40 and penetrating oil, but it just won't free up.
Any suggestions on freeing it up? I thought about heating with a butane torch.
Thanks,
Charlie
   / Baltimatic Spreader - Frozen Agitator Pin #2
charlie put a little heat to it then try prying it off. a propain torch should be able to get it hot enough. good luck
I tried heat, penetrating oil, WD-40, and everything else I could think of. Finally I loaded it up and took it to my welder. He called later to tell me it was fixed. I asked what he did, and he said he just put a little oil on it. Go figure. :)
PALLET OF PICKUP HITCHES (A50854)
PALLET OF PICKUP...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2005 Sterling Acterra Tender Truck (A51039)
2005 Sterling...
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
Kraus Drive Over Fertilizer Conveyor (A50514)
Kraus Drive Over...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
