Baltimatic Spreader - Frozen Agitator Pin
   / Baltimatic Spreader - Frozen Agitator Pin #1
FarmerCharlie
Auburn, AL
JD 2130 and 1020
I have been using my Baltimatic 80 spreader for years with no problems. It has an agitator attachment that I used a few times when spreading lime, but have not used lately. When I needed to use it again, I could not get the connector pin (Item 5 in the first image) to swivel up to attach the agitator.
It was frozen to the shaft. I tried prying it and soaked it in WD40 and penetrating oil, but it just won't free up.
Any suggestions on freeing it up? I thought about heating with a butane torch.
Thanks,
Charlie
   / Baltimatic Spreader - Frozen Agitator Pin #2
charlie put a little heat to it then try prying it off. a propain torch should be able to get it hot enough. good luck
I tried heat, penetrating oil, WD-40, and everything else I could think of. Finally I loaded it up and took it to my welder. He called later to tell me it was fixed. I asked what he did, and he said he just put a little oil on it. Go figure. :)
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55788)
2012 Chevrolet...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
John Deere 1025R Compact Tractor (RIDE AND DRIVE) (A50775)
John Deere 1025R...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
