Baltimatic Spreader - Frozen Agitator Pin
   / Baltimatic Spreader - Frozen Agitator Pin #1
FarmerCharlie
Auburn, AL
JD 2130 and 1020
I have been using my Baltimatic 80 spreader for years with no problems. It has an agitator attachment that I used a few times when spreading lime, but have not used lately. When I needed to use it again, I could not get the connector pin (Item 5 in the first image) to swivel up to attach the agitator.
It was frozen to the shaft. I tried prying it and soaked it in WD40 and penetrating oil, but it just won't free up.
Any suggestions on freeing it up? I thought about heating with a butane torch.
Thanks,
Charlie
   / Baltimatic Spreader - Frozen Agitator Pin #2
charlie put a little heat to it then try prying it off. a propain torch should be able to get it hot enough. good luck
I tried heat, penetrating oil, WD-40, and everything else I could think of. Finally I loaded it up and took it to my welder. He called later to tell me it was fixed. I asked what he did, and he said he just put a little oil on it. Go figure. :)
Self Dumping Hopper (A53316)
Self Dumping...
Informational Lot - Financing (A55301)
Informational Lot...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A55788)
2007 Ford F-150...
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
2013 Ford F-150 (A53422)
2013 Ford F-150...
