Thanks guys, ya'll are great. I put up some pictures of the unit for reference. I do not know if the pressure release works or not. I have never changed any settings only installed filter, cleaned and filled hyd. tank, had a shop go through the motor, and had the cylinder redone because it was pouring fluid out on the return stroke. The pump is rated for 2500 psi. Here it is:
Amazon.com: Parker D22AA2A 0.522 4.1 Gpm Sae Aa Parker Gear Pump-D Series: Industrial & Scientific
The CVA-200 Energy valve is as close as I could find. I did not take it off to see any numbers on the bottom side but it looks the same.
http://www.energymfg.com/pdf/16445x.pdf
I have not been able to take the so called plug out that is above the return port to see if there is an adjustment inside. I can't get it to turn. If the pressure release is not working, or does'nt have one, would that cause the cylinder to stop at 800 psi?
