So why the rear finish mower...
   / So why the rear finish mower... #21
I have used both. I used a BX for 9 years-that had the excellent MMM, and was my mowing machine. I bought a ZTR 3 years ago, and that is now my primary mowing machine. I bought a B2620, and did not plan on mowing with it-until I found a used RFM at a good price. Now, I use the tractor and the RFM when I mow a wide open 9 acre field I own-the field is rough in spots, and it is more comfortable using the tractor.
After these experiences, I would still rather have a MMM if mowing was a primary chore for the tractor, I only had one piece of equipment, and my mowing was around a house, obstacles, etc.
Will
   / So why the rear finish mower... #22
I have both a RFM and MMM for my 2520. I feel the RFM actually gives a nicer cut, probably because it follows the terrain better.
Also, you can get a RFM with rear discharge, which tends to spread the clippings out better than a side discharge. There aren't many rear discharge MMM's around.
Another advantage of a RFM is that you can use it for ballast for the loader if you have one.
   / So why the rear finish mower... #23
Also, you can get a RFM with rear discharge, which tends to spread the clippings out better than a side discharge. There aren't many side discharge MMM's around.
As here:
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A54865)
2006 Volvo VNM...
19010 (A55853)
19010 (A55853)
John Deere BD1108 (A50123)
John Deere BD1108...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55314)
2023 New Holland...
2015 Hyundai Veloster Hatchback (A55758)
2015 Hyundai...
