Not sure how many responses I'll get, but...
   / Not sure how many responses I'll get, but... #21
Sometimes I push my BX23 to the limit and wish the limit was a little higher.
It was a little tippy on my hill property and having the rear tires foam filled made a world of difference both in stability and better all around performance when moving heavy loads with the bucket and using the backhoe.
About the only thing I was a little disappointed about was getting 3 flats in 4 weeks... just thought the tires could be a little more robust... not a problem now that they are foam filled.
   / Not sure how many responses I'll get, but... #22
I have a Kubota B2620, and the lack of position control is the item I wished I had. There are other things, like telescoping lift arms, that I would like to have-but I understand that stepping up to a premium tractor would have made that possible.
Will
You can get those telescoping stabilizers from Tractorsmart.com or maybe your dealer can get you a better deal.
   / Not sure how many responses I'll get, but... #23
What I like least about my 2310: The dash is very cluttered, and a real pain to keep clear so I can see the gauges while snowblowing. The RPM/hour meter is way too small and has no light (I added lights to the fuel and aftermarket temp gauges).
The rocker pedal for the HST works OK, but I find when I really push it in reverse, I'll lift my butt off the seat and activate the kill switch.... being able to push against the seat BACK for reverse would be useful.
I should point out that all of these issues were corrected on the newer 2400 and 2600-series tractors!:thumbsup: I almost traded up, but didn't feel I could afford it....:(
   / Not sure how many responses I'll get, but... #24
The only thing I strongly dislike is the electronic instrumentation. Would much prefer actual gauges to this gimcrackery.
   / Not sure how many responses I'll get, but... #25
What I least like about the GC2400, the colour. Since I'm really a JD man it would have been nice if the tractor was green not red.:D Other then the colour I'm quite pleased with it so far. Maybe the red will start to grow on me.:laughing:
   / Not sure how many responses I'll get, but... #26
I sometimes wish I had more front end loader capacity. Another minor niggle is the instrument cluster. Not how I would've designed it but I'm used to it now. Other than that, my BX2660 suits me well.
   / Not sure how many responses I'll get, but... #27
I don't like a clutch on an HST tractor such as on Kubota. I can live with it, but don't see the point.
   / Not sure how many responses I'll get, but... #28
I wish My JD 4310's CX 300 loader was self leveling, also wish I had a 2 speed pto.
JB
   / Not sure how many responses I'll get, but... #29
My B-I-L's NH doesnt have a clutch. Stall the engine some time and you will see the advantage of having a clutch. His was stuck in gear and had to wait till hydro pressure bleed off before he could shift and start. Wasnt a big deal at the time, he wasnt on a railroad track with a train coming, but it did take a little bit for it to bleed off.
   / Not sure how many responses I'll get, but... #30
What I dislike about my LS P7010 is the plastic fuel tank and the way it is mounted low which would be easy to puncture with a limb or something.
While easy to reach from the ground, it is still chest high so it would still be a little awkward to fill with cans but who fills a 20 gallon tank with cans. Since I fuel with a pump, a high mounted tank like NH tractors with it behind the seat would have been great. There are also switches mounted behind the seat that would have been better mounted forward a bit, especially the differential lock and 4 WD selector. Nothing like being in a slippery situation and having to fumble around behind you for 4wd or diff lock. Other than that, I like the rest of the layout a lot.
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A52705)
2012 VOLVO A40F...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2005 Big Tex Trailer Trailer (A52377)
2005 Big Tex...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
