Deck shakes and cuts off when trying to engage
   / Deck shakes and cuts off when trying to engage
   / Deck shakes and cuts off when trying to engage #32
If I remove the belt and engage the pto and the motor still runs, I would be led to believe the electric clutch is the culprit since it's not under load. If it cuts off, I would think a bad switch. Correct?
If it continues to run,I would think that something after the cluch, is putting a heavy load on the engine,causing it to stall.
the only thing that may cause the clucth to bind ,would be a bad idler bearing on the pulley that is part of the pto assembly.
If your clutch is fully engaging when you flip the switch, I dont beleive there is a problem with your clutch or switch.
   / Deck shakes and cuts off when trying to engage #33
There is a SLIGHT chance that the clutch has something loose that lets is bind when there is a side load placed on it, but generally, I agree with you.
Aaron Z
   / Deck shakes and cuts off when trying to engage #34
I just thought of something (someone else may want to chime in on this) I beleive there is some type of breaking system on the PTO clutch,is it possible this could be the problem?( break not reliesing?)
When I set the gap to specs, I can hear the cover on the clutch rubbing as I turn the pulley. The sound is like metal to metal.
   / Deck shakes and cuts off when trying to engage #36
Chooglin- See posts 17 & 18. Been there, Done that! ~S
I have ordered a new clutch. I may be wasting money, but I can't figure out where else to look. All the pulleys on the deck spin great. I took the belt off the drive pulley and switched the PTO on and it didn't die. So I'm stumped as well. I hope the clutch comes in by Sat. I'll almost have a new zero turn by the time I'm done.
Just installed new clutch and all is well. Thanks everyone for your help.
   / Deck shakes and cuts off when trying to engage #39
Good, 3 weeks on a clutch is enough! Glad you're going.
Jim
   / Deck shakes and cuts off when trying to engage #40
Hmmm,
Something smells odd.
Well, keep an eye on your clutch for further problems..
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
2006 MACK CV713 KILL TRUCK (A50854)
2006 MACK CV713...
RoGator 844 sprayer (A50490)
RoGator 844...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
CAT RM-300 (A50854)
CAT RM-300 (A50854)
