Loader Any MF 1260/1246 owners willing to lend a hand?
   / Any MF 1260/1246 owners willing to lend a hand? #11
Rear spools. And an artistic smattering of grass.
Quick attach bucket
Hydro piping up to joystick.
   / Any MF 1260/1246 owners willing to lend a hand? #12
Hey, let me know if you need more.
   / Any MF 1260/1246 owners willing to lend a hand? #13
I have a leaky seal. Hopefully tomorrow my seal kit will be here.
Thanks for the pics!. In the 2nd one, I assume the hose goes out to the FEL valve's In port (pressure) and in the 3rd one, one side of the QC is the hose shown in the 1st pic and the other goes to the loader valve return.
Is that correct?
Jeff
   / Any MF 1260/1246 owners willing to lend a hand? #15
That seems to be correct.
   / Any MF 1260/1246 owners willing to lend a hand? #16
I'm pretty sure on the 1260 you didn't use the aluminum manifold block. The hose that went from the manifold to the 3pt just got the connections changed to fit the loader. Either way, that "T" has got to go.
The feed to the loader came from the connection closest to the front of the tractor and the return went to the hose going to the 3pt. If a Power beyond was used, there was a direct to sump plumbed in the side of the transmission housing.
   / Any MF 1260/1246 owners willing to lend a hand? #18
I can snap some more photos if you need. Mine works the way it should and i have a 1250. So the only difference is the turbo I believe?
The 1260 came standard with draft control (which is one of the pieces to this puzzle) while it was an option on the 1250 (one other difference is the 1260 has an oil cooler). If your three point control was just one lever, you don't have DC.
Thanks for the pictures, I have enough for now. I'm trying to find out now what the deal is with the two port manifold block which doesn't seem to be in any of the AGCO parts books for the 1260. I'm thinking it came off another tractor (prolly the one the loader was originally on) and the previous owner pressed it into service, but that's just a guess.
   / Any MF 1260/1246 owners willing to lend a hand? #20
Do you mean the connection on the manifold block or is there another pressure connection somewhere?
The connection where your "T" is now would be the feed to the 3pt. If you seperate that, rmove the"T" and run it into the loader first, then to the 3pt, that would be how it would have been plumbed originally.
2014 Chevy Malibu Sedan (A56859)
2014 Chevy Malibu...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Sedan (A59231)
Sedan (A59231)
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
1972 Chevrolet Cheyenne 10 4x4 Pickup (A57453)
1972 Chevrolet...
