Tires L-3130-HST right tire wear on outside. front axle problem.
   / L-3130-HST right tire wear on outside. front axle problem.
The bearings on the right side that is giving me the problem was just changed last spring. You could see that the tire is at a different angle than the left. It was noticed shortly after I changed the bearings but I wasn't concerned about it. I did adjust the toe in after changing the bearings, spindle and bell end cover. I will check the toe in again and tire pressures.
With the tire off you can see the hub is at a different angle. It is hard to see it in the puicture.
I checked the toe in. It is 1-3/4" less in the front than it is in the back. I checked the angle of the tire while jacked up. Going by a level, it was 1/4 " more of an angle on the right than on the left. The top being angled out and the bottom in. Both are tied together still. If I spin one tire the other spins in the opposite direction when jacked up.
I need to figure this out real soon because I need to get new tires on it quick, the right tire now has a good size bubble in it.
It is driven on the road for about two miles about once a week. We are usually careful about not keeping it in 4wd on the pavement.
   / L-3130-HST right tire wear on outside. front axle problem. #13
1 3/4 is a lot of toe in. What does your manual call for?????
   / L-3130-HST right tire wear on outside. front axle problem. #14
That is a lot of toe in, something more like 1/4" is normal. Are you steering tie rod ends still tight?
   / L-3130-HST right tire wear on outside. front axle problem. #16
   / L-3130-HST right tire wear on outside. front axle problem. #17
Wow, I know my dealer did not set that much on mine. My tires would be gone in no time with all the road driving I do.
my manual calls for 2" toe in.
   / L-3130-HST right tire wear on outside. front axle problem. #20
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
1111 (A57192)
1111 (A57192)
2008 Ford E-350 Passenger Van (A55852)
2008 Ford E-350...
Club Car Electric Cart (A55758)
Club Car Electric...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2018 Kubota L2501 (A53317)
2018 Kubota L2501...
