Previous lurker, but now new member due to unusual brakedown. This is on a 2001 TC35d with hydrostatic transm. Owned since 2004, 950 hours; the lift arm shaft broke within the splined receiver yolk of the lift arm on the left side. This happened a day after using the boxblade to dig out a small pond, but I have moved many hundreds of yards of dirt over the past 7 years. I can't believe the almost 2" diameter shaft would break without a catastrophic high speed hangup, but it did. A friend that looked at it said there was evidence of crystallization within the break (whatever that means).
I have searched tractorbynet and elsewhere for info on changing the shaft to no avail. Two different NH dealers quoted >$1300 for the repair because they said they had to remove the lift cover (after removing fenders/seat/rops/fueltank...) to replace the shaft.
The shaft moves sideways readily with light tapping on the broken side. I am wondering if i could just disconnect the rops and lift it enough to be able to slide the old one out and new one in without taking the lift cover off and all that involves. Looking at a parts diagram the center splined area of the shaft fits through a splined "arm" inside the hydraulic cylinder, but would this move out of position when the old one was removed such that the new one could not be slid in place? Also, should I replace the springs, o-rings and bushings on either side of the shaft even if they look OK.
Any advice appreciated. Parts diagram attached.
Thanks
Thanks
