I figured a strap or something. Is it shown in your pic? Even with glasses, I can't see the strap?![]()
They don't come with the platform.
Could that work?
I understand about the strength of the boards. However, I did not mean to use the carry-all frame to move pallets - I meant to ask how feasible it would be to use the pallet itself as the platform for the carry-all, assuming you found a pallet with thick boards. I've seen pallets that had thin boards, and pallets that had pretty thick boards (3/4" or 1"). What I had envisioned was, using a trimmed-down pallet as the storage base for a barrel filled with concrete; this could be left in a corner of the shop when not being used. When it came time for some rear ballast, the tractor could be backed up so the carry-all's arms slid into the pallet, and the latter bolted to the arms. Then the barrel could be secured to the carry-all with a strap, and off you'd go with the combination as your rear ballast. The pallet would make it easier to store the concrete barrel, and you wouldn't need to use angle iron with hitch points inserted in the barrel as the concrete was poured. Heck, if a pallet would not be strong enough, a beefier version could be made up using 2x4's or such.
Could that work?
At least you'd have a useful, albeit narrow, box blade, instead of just carrying around dead weight that has no other purpose/ usefulness.
You know everyone has their opinion of Ballast Boxes. But I find my Ballast Barrel very useful, it carries my handle tools, my chains, spare water, extra clothing sometimes, or anything I want to throw in it. It is heavy, and very compact up close to the tractor which is important to me in the woods, to keep from backing into or sideswiping a tree. I also use it with its built in 2 inch receiver to carry my sprayer, and am considering putting a salt spreader on it for next winter. I sure get a lot of use out of mine![]()
That setup looks like it might actually be bigger (extending rearward) overall than the 4' box blade idea, no?
That does seem like a fine place to store all that "stuff", chains, etc., but what do you do with all of that when you have say a box blade or rotary cutter on the back? Or does your ballast barrel stay on full-time?
Heck, this discussion is making me think I need to invent a box blade with storage on top :thumbsup: ('course my question would still apply)
Recently, I emailed Everything Attachments to see if they sold ballast boxes on their web site, since a search failed to turn up that implement. The response I got ran in part thus:
That struck me as an odd response, and faintly condescending. I wanted to check with you experienced folks about whether or not a ballast box really is "useless." I had the impression that BB's would work nicely in tight confines such as in wooded areas and near buildings and fences, but maybe I just don't know anything?![]()
I recently built my own concrete block "ballast box" (search for ballast box build, just posted pics of the block with form removed).
On my tractor (Kubota M7040SUD with 1153 loaderr), the loader itself weighs 2000lbs and it will lift close to 3000lbs.
That makes me wonder, do the more powerful tractors need more ballast, or does it go in proportion? Nobody's talking about using a loader with nothing on the back, but my CK feels pretty stable with just a cheap box blade. I've had a rear tire come up while operating at the extreme, but generally no problem. Do most people load up with ballast untill it's impossible to get it light in the rear?
