Am I being a noob about ballast boxes...
   / Am I being a noob about ballast boxes... #51
Could that work?
Absolutely no reason you couldn't make a pallet with permanent ballast and use it for that purpose only. You just need to figure out how to prevent any shifting of the ballast (on the pallet). That could be something as simple as a box nailed down then filled with sand, concrete or what ever you have handy.
I looked at a carry all last time I was at Tractor Supply. Those "forks" are welded in place, so they won't fit every pallet you come across.
There are 3PH pallet movers (forks adjust in width) available. Can't recall where I saw one, but it might have been TSC's website (or Northern Tool).
   / Am I being a noob about ballast boxes... #52
I understand about the strength of the boards. However, I did not mean to use the carry-all frame to move pallets - I meant to ask how feasible it would be to use the pallet itself as the platform for the carry-all, assuming you found a pallet with thick boards. I've seen pallets that had thin boards, and pallets that had pretty thick boards (3/4" or 1"). What I had envisioned was, using a trimmed-down pallet as the storage base for a barrel filled with concrete; this could be left in a corner of the shop when not being used. When it came time for some rear ballast, the tractor could be backed up so the carry-all's arms slid into the pallet, and the latter bolted to the arms. Then the barrel could be secured to the carry-all with a strap, and off you'd go with the combination as your rear ballast. The pallet would make it easier to store the concrete barrel, and you wouldn't need to use angle iron with hitch points inserted in the barrel as the concrete was poured. Heck, if a pallet would not be strong enough, a beefier version could be made up using 2x4's or such.
Could that work?
Yes, that would work. I have something similar that is used to haul around a generator, welder, and air compressor.
The carry-all base is made from angle iron so is not quite as strong as rear pallet forks that Roy mentioned. They also may require a bit more clearance when entering the pallet. You could build the pallet with 2x6 verticals instead of 2x4 and solve that problem.
   / Am I being a noob about ballast boxes... #53
At least you'd have a useful, albeit narrow, box blade, instead of just carrying around dead weight that has no other purpose/ usefulness.
You know everyone has their opinion of Ballast Boxes. But I find my Ballast Barrel very useful, it carries my handle tools, my chains, spare water, extra clothing sometimes, or anything I want to throw in it. It is heavy, and very compact up close to the tractor which is important to me in the woods, to keep from backing into or sideswiping a tree. I also use it with its built in 2 inch receiver to carry my sprayer, and am considering putting a salt spreader on it for next winter. I sure get a lot of use out of mine:)
   / Am I being a noob about ballast boxes... #54
That setup looks like it might actually be bigger (extending rearward) overall than the 4' box blade idea, no?
That does seem like a fine place to store all that "stuff", chains, etc., but what do you do with all of that when you have say a box blade or rotary cutter on the back? Or does your ballast barrel stay on full-time?
Heck, this discussion is making me think I need to invent a box blade with storage on top :thumbsup: ('course my question would still apply)
   / Am I being a noob about ballast boxes... #55
Well the sprayer is only on occasionly, and comes right off the 2 inch receiver, the ballast barrel is considerably shorter and much narrower by itself than a box blade. the barrel of course comes off for the rotary cutter, and I rely on the loaded tires for stability on the hills. the ballast barrel is on the tractor most of the time (loader/fork work is what I do the most). However your Idea of a storage/weight box on top of a BB may not be a bad idea. When I lived in open country, I never had a Ballast box of any kind, I didn't need it. I left the mower on all the time for ballast for loader work, and had loaded tires. It worked fine, I did not worry about hitting things much, because there wasn't much to hit in the fields. I carried the tools in the bucket and dumped them on the ground more than once, and darn near ran over my chainsaw once:laughing: But hey different strokes for different folks, and whatever floats your boat. I really like my ballast box setup, it works well for me:thumbsup:
James K0UA
   / Am I being a noob about ballast boxes... #56
Recently, I emailed Everything Attachments to see if they sold ballast boxes on their web site, since a search failed to turn up that implement. The response I got ran in part thus:
That struck me as an odd response, and faintly condescending. I wanted to check with you experienced folks about whether or not a ballast box really is "useless." I had the impression that BB's would work nicely in tight confines such as in wooded areas and near buildings and fences, but maybe I just don't know anything? :p
I am a tractor newb of about 2 years experience. However, I have developed 2 peeves. They are....
1) If you have a Front-End-Loader your tractor MUST HAVE a Ballast Box. Period. (this is my opinion and I stand by it, and I always will.!!)
2) I ain't NEVER putting ANYTHING in my rear tires other than air.
I have 4 attachments...Rear Blade, Rear Rake, Rear Snowblower and a Ballast Box. Guess which attachment is my favorite.??....You got it...the Ballast Box.!!:thumbsup::thumbsup::thumbsup::D
   / Am I being a noob about ballast boxes... #57
I agree, that response did come across as condescending. And it's something that people buy and I'm sure they could make a profit selling, so I'm not sure why they wouldn't carry them. I recently built my own concrete block "ballast box" (search for ballast box build, just posted pics of the block with form removed). It's really a concrete block with no exterior box around it. In my case, I don't have an implement that weighs nearly as much as the block I created (~2000 lbs). There are box blades that go over 1000lbs, but they're very expensive. I was able to make my block for about $140, and that's with the more expensive crack resistant concrete. Using regular would have cost less. On my tractor (Kubota M7040SUD with 1153 loaderr), the loader itself weighs 2000lbs and it will lift close to 3000lbs. So, a box blade hanging off the back isn't going to counter it much. Even for smaller tractors, the weight of the loader and it's capacity can be significant.
I was the first one to comment on your BB project :D You did a great job, though any such BB I might build would weigh considerably less. Perhaps 800 lbs. But thanks for the comments!
   / Am I being a noob about ballast boxes... #59
That makes me wonder, do the more powerful tractors need more ballast, or does it go in proportion? Nobody's talking about using a loader with nothing on the back, but my CK feels pretty stable with just a cheap box blade. I've had a rear tire come up while operating at the extreme, but generally no problem. Do most people load up with ballast untill it's impossible to get it light in the rear?
   / Am I being a noob about ballast boxes... #60
If a rear tire came up, you lost most of your traction a long time ago. It's really about traction. And it's all about operating margin. You can be working just fine without weight and then get a heavy load with front end down hill and suddenly be in a world of hurt. If you start sliding with the back end light, there's not a lot you can do.
SKID STEER ATTACHMENT (A58214)
SKID STEER...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
43024 (A59228)
43024 (A59228)
Teakwood Horse Stool (A57454)
Teakwood Horse...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
