Abby Cultipacker??
   / Abby Cultipacker?? #1
Agrantina
West Tennessee
Kubota L3240 GST
I found out today that their cultipacker is 53 1/2 wide and weighs #290 lbs.. Not bad for brand new at $479--- easly add 100lbs to it...
AndyG
   / Abby Cultipacker?? #3
AndyG
If you add 300 pounds to that, then, you will be able to cultipack. I am afraid if you add that much weight to the machine the Chinese packer wheels and end bearings will not hold up very long. Those Chinese packer wheels are only $8.49 each at agri supply. Ken Sweet
   / Abby Cultipacker?? #4
A ring roller has a large diameter pipe for a axle and the rings are left to float. These smaller rings have hole to insert a solid axle shaft 1-3/4", I think. The rings can't float or follow the ground contour as well. I wonder if anyone has thought about cutting out the spoke and mounting them on a pipe like the big guys? I would think it would work if the rings hold up. bjr
   / Abby Cultipacker?? #5
A real 6 ft cultipacker should look like this and weigh around 800 + lbs. Ken Sweet
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2021 Case 221F Wheel Loader (RIDE AND DRIVE) (LIKE NEW) (A50775)
2021 Case 221F...
CLUB CAR (A55758)
CLUB CAR (A55758)
UNUSED (2) 3500# DROP AXLE W/ BRAKES (A54756)
UNUSED (2) 3500#...
