Abby Cultipacker??
/ Abby Cultipacker?? #1
Agrantina
Platinum Member
West Tennessee
Kubota L3240 GST
I found out today that their cultipacker is 53 1/2 wide and weighs #290 lbs.. Not bad for brand new at $479--- easly add 100lbs to it...
AndyG
/ Abby Cultipacker?? #3
AndyG
If you add 300 pounds to that, then, you will be able to cultipack. I am afraid if you add that much weight to the machine the Chinese packer wheels and end bearings will not hold up very long. Those Chinese packer wheels are only $8.49 each at agri supply. Ken Sweet
/ Abby Cultipacker?? #4
A ring roller has a large diameter pipe for a axle and the rings are left to float. These smaller rings have hole to insert a solid axle shaft 1-3/4", I think. The rings can't float or follow the ground contour as well. I wonder if anyone has thought about cutting out the spoke and mounting them on a pipe like the big guys? I would think it would work if the rings hold up. bjr
/ Abby Cultipacker?? #5
A real 6 ft cultipacker should look like this and weigh around 800 + lbs. Ken Sweet
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
More info coming soon (A61574)
More info coming...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
LOT OF 2" SQUARE TUBING (A64278)
LOT OF 2" SQUARE...
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
