Horse Paddock Drainage - Clay
   / Horse Paddock Drainage - Clay #11
Trying to divert the water away won’t help. Every time a horse takes a step it creates a divot. That divot holds a small amount of water, which makes the ground soft. Then the next divot is deeper because the ground is softer. And so on, and so on …. It just keeps getting worse until it dries up in the summer. I deal with it with cattle as well. Here’s the best solution I’ve seen. The fabric is key.
Viewing a thread - Gravel lane picture
   / Horse Paddock Drainage - Clay #12
How many horses are we talking about?
I have two and know how much ground distrubance they do in the spring. Our land is also on a side slope and we are in heavy snow country as well. Also soil over clay base.
Our pasture is cross fenced and we keep them on the highest level as it dries up faster. How ever our pastures are also somewhat rolling which creates natural changes in elevation, The horses are pretty smart they know where to go to dry out the hooves.
Maybe instead of true ditching you could creat some shallow swales to a good run off spot. the horses can walk through or jump and the water always chooses the path of least resistance. I am thinking something say 10 to 15 feet across at the top to a center depth of 2 to 2-1/2 feet
   / Horse Paddock Drainage - Clay #13
We didn't put our pea gravel down to create dry areas. We put it down for a riding surface. It doesn't sink into the mud like sand or anything else we have tried. It won't pack. The only thing is that is a real pain to remove snow from pea gravel. It is as fluffy as snow and it's hard to tell the difference.
   / Horse Paddock Drainage - Clay #14
Our solution for this is a material called spaghetti hog but trying to hog an area of 2 - 3 acres would be expensive. Spaghetti hog is a forest by product, wood chippings in long strands that weave together to form a mat. We winter our two horses in a smaller area, about half an acre, where we have spaghetti hog throughout to a depth of about 3". Cost initially was around $2400 and we need an additional load per year for maintenance which costs around $600 delivered.
The stuff provides a soft surface for the horses to run around in, stops the area from turning to mud and mush.
We've also put the hog throughout our riding ring and on the surface of the access road up to it. I've attached a shot that shows the material.
   / Horse Paddock Drainage - Clay #15
Sounds like you need 'drain tile'. A friend was describing an old farming field he has. And the professional ball fields have pretty fancy drains under them. Out with a potato digger, some geo fabric, gravel, etc to me.
I have used a chipper over the years for on the spot shavings. Ok, a use for the old stuff I have been stacking for the past summer. In any case, it is good stuff for the inevitable low spots. And it's good for the ground in any case. Yes, short term, but you can't get it all at one time.
http://en.wikipedia.org/wiki/Tile_drainage
   / Horse Paddock Drainage - Clay #16
+1 in the field drainage tile.
And not just one line either. Get with a reputable tiling crew and install as many lines as they suggest. That will take care of your spring time ground saturation and make it easier to absorb and shed heavy rains.
   / Horse Paddock Drainage - Clay #17
i used 2 layers (10-12") of 1-1/4 and 5/8 minus gravel base for my paddock areas and fenced them in. they are about 15'x60' and have a 12x14 covered shelter on one end.. this solved my mud problem after fighting it for a couple winters and trying other types of footing (hog fuel, sand, straw, etc). no need to get elaborate mesh, geotext, etc. keep it simple. i keep a seperate sacrifice area which i haven't done anything with. it gets muddy but the horses can at least get out during the day and burn off some energy running, kicking, snorting, whatever. we always wash their feet off when we bring them off of it because the mud will dry around their feet/ankles and cause mud rot which is not pretty.
   / Horse Paddock Drainage - Clay #18
In central Maine we have the blue clay and the wet spring and wet fall conditions. The spring is the worst as the ice melts out of the ground. The 2 horses kill whatever they walk on. If manure gets worked in - within 2 years there's 6" of muck to go through. Adding shavings, sawdust, old hay helps for a day or two but then makes it all really worse - churned muck.
I ditched all around the riding area with open ditches sloped to carry the water away. I sloped the riding area with a high and low point to carry the water away. Then I added gravel with 1" stones 5" to 8 " deep. (all done with delivered gravel, a mini backhoe (Northern tool) and front end loader.)
It has taken a couple of years- but the ground is good as soon as the snow melts for the horses. I work to clear the manure off it (important). I build small roadways for the horses to move to the back field by ditching both sides of the road and dumping the dirt to raise the level of the road then smooth and slope it for runoff. I slope the ditch sides so the horses and step down and up easily. I've covered the road with 5-6 inches of gravel and I have dry roads now with constant running water in the ditches on both sides. Great for their feet and I can drive on it with the tractor - even though the fields have standing water in places.
Figure out where the water goes naturally, then help it get there with the ditches. I do use a culvert when I have to. For a riding ring I would slope lengthwise. Then I would add a ridge running lengthwise down the middle and slope the gravel sideways left and right. Sideways from the middle- the water has less distance to travel to be off it. The long lengthwise slope just encourages all of the water to move out of the area altogether. I think the water both runs off and what amount does go down through the packed gravel, runs off on the dirt below. I think you could add a layer of finer gravel to make a smoother riding surface.
Add manure/clay/organic etc. and the muck will come back. My wife dumped some scoopable cat litter in a wet spot near an edge and covered it with gravel- now that's a slick slimy clay spot. Clay is only good if it is dry - inside a stall where water and moisture cannot travel upwards from the ground.
Good luck.
   / Horse Paddock Drainage - Clay #19
I ditched all around the riding area with open ditches sloped to carry the water away. I sloped the riding are with a high and low point to carry the water away. Then I added gravel with 1" stones 5" to 8 " deep. (all done with delivered gravel, a mini backhoe (Northern tool) and front end loader.)
It has taken a couple of years- but the ground is good as soon as the snow melts for the horses. I work to clear the manure off it (important). I build small roadways for the horses to move to the back field but ditching both sides of the road and dumping the dirt to raise the level of the road then smooth and slope it for runoff. I slope the ditch sides so the horses and step down and up easily. I've covered the road with 5-6 inches of gravel and I have dry roads now with constant running water on both sides. Great for their feet.
Figure out where the water goes naturally, then help it get there with the ditches. I do use a culvert when I have to. For a riding ring I would slope lengthwise. Then I would add a ridge running lengthwise down the middle and slope it sideways left and right. Sideways from the middle- the water has less distance to travel to be off it. The long lengthwise slope just encourages all of the water to move out of the area altogether.
Add manure/clay/organic etc. and the muck will come back. My wife dumped some scoopable cat litter in a wet spot- that's a slick slimy clay spot now.
Good luck.
   / Horse Paddock Drainage - Clay #20
Skim off a few inches of surface and store it in a pile. Grade the remanent surface to the natural slope. Lay down a thin layer of sand followed by geotextile. On top of this put down 2-3 inches [total] of sand and gravel, then another layer of geofabric. Top with at least 4 inches of gravel clay mix. Youll have to touch up the top from time to time as the horses compact it with their hi heels, but itll end your muck by preserving the permeable drain sandwich below.
larry
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
TAG 23" EXCAVATOR BUCKET (A57192)
TAG 23" EXCAVATOR...
2017 Jeep Grand Cherokee SUV (A55853)
2017 Jeep Grand...
2019 Harley Davidson (A56859)
2019 Harley...
