recommended lube for 3-PT ball fittings and similar
   / recommended lube for 3-PT ball fittings and similar #11
JD super lube is silicone spray.
Ralph
   / recommended lube for 3-PT ball fittings and similar #12
I use lock ease. Comes in a small aerosol can and uses graphite in a liquid carrier that dries. It will not attract dirt.
   / recommended lube for 3-PT ball fittings and similar #13
What's a good lubricant for all those external parts that need to be slippery such as 3-pt hitch ball fittings, FEL engagement pins, and such?
I usually just use stray grease, but the best thing going is motorcycle chain lube.
JayC
   / recommended lube for 3-PT ball fittings and similar #15
You have two types of people...the greasers and the non-greasers. I am a non-greaser. I don't bother with any kind of lubrication on the ball fittings. I think any kind of lube attracts dirt which causes more wear. Then there's the messy problem of getting the dirty grease on everything when trying to hook up an implement. So that's why I like to keep the ball fittings dry.
   / recommended lube for 3-PT ball fittings and similar #16
i refrain from greasnig my balls.. makes htem pick up dirt and grit and wear out worse.
soundguy
   / recommended lube for 3-PT ball fittings and similar #17
Uh oh...I think I know where this thread is headed now...
   / recommended lube for 3-PT ball fittings and similar #19
soundguy
So...what's your wife think about that...?
   / recommended lube for 3-PT ball fittings and similar #20
Looks like its headed down hill from here
10 Misc. Chairs (A50325)
10 Misc. Chairs...
Year: 2013 Make: Ford Model: Edge Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 217,869 Plate: (A51694)
Year: 2013 Make...
2 Engines and Transmission pallet (A50325)
2 Engines and...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
