recommended lube for 3-PT ball fittings and similar
   / recommended lube for 3-PT ball fittings and similar #11
JD super lube is silicone spray.
Ralph
   / recommended lube for 3-PT ball fittings and similar #12
I use lock ease. Comes in a small aerosol can and uses graphite in a liquid carrier that dries. It will not attract dirt.
   / recommended lube for 3-PT ball fittings and similar #13
What's a good lubricant for all those external parts that need to be slippery such as 3-pt hitch ball fittings, FEL engagement pins, and such?
I usually just use stray grease, but the best thing going is motorcycle chain lube.
JayC
   / recommended lube for 3-PT ball fittings and similar #15
You have two types of people...the greasers and the non-greasers. I am a non-greaser. I don't bother with any kind of lubrication on the ball fittings. I think any kind of lube attracts dirt which causes more wear. Then there's the messy problem of getting the dirty grease on everything when trying to hook up an implement. So that's why I like to keep the ball fittings dry.
   / recommended lube for 3-PT ball fittings and similar #16
i refrain from greasnig my balls.. makes htem pick up dirt and grit and wear out worse.
soundguy
   / recommended lube for 3-PT ball fittings and similar #17
Uh oh...I think I know where this thread is headed now...
   / recommended lube for 3-PT ball fittings and similar #19
soundguy
So...what's your wife think about that...?
   / recommended lube for 3-PT ball fittings and similar #20
Looks like its headed down hill from here
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
2019 Dodge Challenger Passenger Car (A51694)
2019 Dodge...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A52748)
2012 KINZE FLAT...
20" Sea Container (A47384)
20" Sea Container...
