New Garage Pole Barn 40 x 64 x 12
   / New Garage Pole Barn 40 x 64 x 12
Bathroom Completed
Both Bedroom Vanity Completed
Peg Board Installed - Tool Boxes moved to Garage
Now I get to start and try and get everything running!
This may take longer than the garage.
Started fabrication of my ATV storage lifts. I will use my tractor FEL to lift them on top of the racks. Should be finished this week. When you have the right equipment things fly by, so I went to a friends shop who has all the goodies. It is how he makes his living.
140' of 1.75 .093 ERW and 40' of 1" .083 ERW. It will be 20' long x 4' wide x 5' off the ground. I will be able to fit 3 ATV's nose to tail.
I laid out the spacing on the 20' rails and cut all the tubing to length on a large metal cutting chop saw with lubrication in an hour. (Much better than an abrasive saw.)
A Piranha ironworker made fast work of the notches for the tubing. All notches were done in less than an hour. You have to check this link if you want to see how it is done.
Pipe/Tube Notching Attachment
My first question to him was how do I keep the end notches paralell when doing both ends of the tubing? Use the weld seam as your line. I guess that should have been obvious.
With all the tubing cut and laid out, there was only one that was not square to the long tubing, so a small additional notch had to be cut.
It is finished and will get painted this weekend. I had about 6 feet of tubing left.
Up and storing.
The view from the seat.
$700 in total project. Freed up a lot of floor space. Cheaper than bricks and motar.
   / New Garage Pole Barn 40 x 64 x 12 #226
Looks like you could use a few more quads.:laughing: Nice looking job though. Looks professional.:thumbsup:
Thanks, I can't take credit for the welding. I did the design and cut the material to size but my welding is not up to par to have heavy objects up in the air so I left it to a pro who builds race cars for a living.
   / New Garage Pole Barn 40 x 64 x 12 #228
It's still your design and it still looks really good.:thumbsup: Besides, I can't see the welds from my house.:laughing:
Keep up the good work. I'm enjoying your thread.
   / New Garage Pole Barn 40 x 64 x 12 #229
ATV rack looks great! I like how compact and tight it is by keeping the toys close to the wall and out of the way. AND, it's painted blue to match the other hydraulic racks in the shop! Looks sharp. You can now park 7 more Miatas in the building...
Brought home from PA over the July 4th weekend. It is only going to be here for a few weeks and then return to visit from my Mom and Dads in the Raleigh NC area.
Say Hi if you see them showing it off.
1960 Ford Falcon with 42,000 miles. We are now the 4th registered owners.
It is sweet. Still needs to be detailed but it is pretty clean. We even have pictures of the original owner when he drove it home to Ohio back in late 1959.
2000 FORD E350 CUTAWAY BOX TRUCK (A52577)
2000 FORD E350...
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A51573)
1 Bridgestone...
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
(INOP) 2019 CATERPILLAR 336 EXCAVATOR (A51246)
(INOP) 2019...
