Laying Water pipe
   / Laying Water pipe #1
BULNUT
South Mississippi
Kubota 3400 hst 4 WD
Looking for recommendations for implement to lay 1" water line, I have a Kubota L3400 4WD. Need to pull line around 300 ft. Any Suggestions?
   / Laying Water pipe #2
I've been looking at a middle buster, or subsoiler.
For one inch pipe you might check out the subsoiler.
   / Laying Water pipe #3
depends on soil and how deep your trying to lay the water line.
Here in No Idaho any water left on year round is 4-5 feet deep (freeze protection). Sprinklers are only 6-8" deep. big difference.
I use an excavator for main lines and a trenching machine for sprinklers
   / Laying Water pipe #4
Well I live up state from you in Brandon. I have a L2800 4WD and have laid about 600' of 1" line in my irrigation project. The sub soiler will work and I have used a middle buster. Run the sub soiler down the path a couple of times and it will remove roots etc. I put a cap on the pipe then tied it to the subsoiler and away I went. It works okay at best in my opinion. Seems like the pipe wants to rise up and does not really get down like you would think it would. However, in our case the water line doesn't need to be much over 6 to 9 inches deep for freezing purposes. The reason you want it deeper is when you run over the line with your tractor it does not break it. If it is too close to the surface you will have problems, though freezing will not be one of them.
After doing several hundred feet of irrigation pipe like this I found a Ground Hog T4 18" trencher and bought it. In about a month when I finish my water lines I will sell the trencher on Craig's list. The trencher is my preferred way to go.
The guy above, grsthegreat, is in nothern Idaho. That's pretty close to the artic circle I think and he must dig pretty deep to keep it from freezing.
   / Laying Water pipe #5
This.
I laid about 600 feet of 1.25" poly line from my creek pump using a middle buster subsoiler. I put it down about 6-8" cross the pasture. Worked great, I had a 24HP Yanmar at the time.
   / Laying Water pipe #6
6-8" baaaaaa. hehe. na, the artic circle is a bit further north.
   / Laying Water pipe #7
Down here in TN, anything underground means underrock. Here's what was needed for laying in my water line....
   / Laying Water pipe #8
yeiks.....and i thought i had it bad.
   / Laying Water pipe #10
Have used subsoiler on several occasions to pull in water lines without issue. Trencher would be the best option, but had subsoiler not trencher.
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59575)
2016 FREIGHTLINER...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
*Selling at Royal Auction Zephyrhills, FL Location* (A59230)
*Selling at Royal...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
