Laying Water pipe
   / Laying Water pipe #1
BULNUT
South Mississippi
Kubota 3400 hst 4 WD
Looking for recommendations for implement to lay 1" water line, I have a Kubota L3400 4WD. Need to pull line around 300 ft. Any Suggestions?
   / Laying Water pipe #2
I've been looking at a middle buster, or subsoiler.
For one inch pipe you might check out the subsoiler.
   / Laying Water pipe #3
depends on soil and how deep your trying to lay the water line.
Here in No Idaho any water left on year round is 4-5 feet deep (freeze protection). Sprinklers are only 6-8" deep. big difference.
I use an excavator for main lines and a trenching machine for sprinklers
   / Laying Water pipe #4
Well I live up state from you in Brandon. I have a L2800 4WD and have laid about 600' of 1" line in my irrigation project. The sub soiler will work and I have used a middle buster. Run the sub soiler down the path a couple of times and it will remove roots etc. I put a cap on the pipe then tied it to the subsoiler and away I went. It works okay at best in my opinion. Seems like the pipe wants to rise up and does not really get down like you would think it would. However, in our case the water line doesn't need to be much over 6 to 9 inches deep for freezing purposes. The reason you want it deeper is when you run over the line with your tractor it does not break it. If it is too close to the surface you will have problems, though freezing will not be one of them.
After doing several hundred feet of irrigation pipe like this I found a Ground Hog T4 18" trencher and bought it. In about a month when I finish my water lines I will sell the trencher on Craig's list. The trencher is my preferred way to go.
The guy above, grsthegreat, is in nothern Idaho. That's pretty close to the artic circle I think and he must dig pretty deep to keep it from freezing.
   / Laying Water pipe #5
This.
I laid about 600 feet of 1.25" poly line from my creek pump using a middle buster subsoiler. I put it down about 6-8" cross the pasture. Worked great, I had a 24HP Yanmar at the time.
   / Laying Water pipe #6
6-8" baaaaaa. hehe. na, the artic circle is a bit further north.
   / Laying Water pipe #7
Down here in TN, anything underground means underrock. Here's what was needed for laying in my water line....
   / Laying Water pipe #8
yeiks.....and i thought i had it bad.
   / Laying Water pipe #10
Have used subsoiler on several occasions to pull in water lines without issue. Trencher would be the best option, but had subsoiler not trencher.
   / Laying Water pipe #12
You might consider using the Blue Poly instead of PVC. It comes in 300' rolls and driving on it and freezing isn't much of an issue. Also no couplings to leak. I like it also because you can turn the water on and test your end fittings before you cover it up. My 2 cents.
   / Laying Water pipe #13
I am in Florida, perhaps a little closer to your climate.
I am also in the irrigation business.
We bury our 1" line with a "ground saw" It cuts a 2" wide trench up to 13" deep and piles the lose dirt next to the ditch. If you have any roots to go through, the saw cuts them also.
If there are no roots to deal with, a "vibra-plow" (or pipe-puller) is another way to go. It will pull the pipe in to a depth about 15" without leaving a ditch to fill.
You should be able to rent either from a good rental place.
If the pipe is going to be in an area that is driven over and your soil is or gets soft (like when it rains), you may want to use the backhoe to bury the pipe so you can lay it 24" or so. That will protect the pipe from the weight of things driving over it.
One other thought ... if you think you will ever need to find that line in the future and are concerned that you may not remember exactly where it runs, bury a single strand buriable wire along with the pipe with a small coil at each end where the pipe ends. This way, a "locator" can be used to locate the pipe run in the future.
   / Laying Water pipe #14
I have plowed in lots of PVC pipe with my subsoiler. Beats the heck out of trenching because its faster and cleaner. No backfilling or settling like with a trench. One pass and you're done. I have pulled as much as 900 feet of 1" pipe at a time. I don't like roll pipe.
I have sandy loam ground and I can lay it 10-12 inches deep in one pass. If you have a small tractor or hard ground you will have to make a dry run or two before you pull the pipe at full depth.
Just weld a ring to the back of your subsoiler foot, drill a hole in a PVC cap, run the rope through the hole and tie a knot in it, glue up your pipe, and tie it to the subsoiler and you're ready to go.
   / Laying Water pipe #15
I made something similar to a subsoiler that I could put into the 2" receiver I have on my ballast box. I had to reinforce it because it was bending but it got the job done in a quick & clean fashion. The ballast box kept the pipe from raising. You could hear it cut through the roots and one root I hit must have been thick because the tractor wheels started to spin. I was going very slow.
   / Laying Water pipe #16
I use a home made "Pickle fork", easy to make could be used on a front end loader. I use mine on a back hoe. Its good for a little over 12" and it will work in rocks & cut roots if not too large. Yours could be made a little longer if need be.
   / Laying Water pipe #17
ive used a 2 row bottom plow took one blade off laid the grass back about 12 inches deep came back laid the grass back in couldnt even tell there was a ditch there but this was in alabama no rocks or big roots
   / Laying Water pipe #18
I used a pipe bender to make an attachment for continuous trenching with a subsoiler. It worked great for my 600' line to a field hydrant. I used 100psi 1" coil pipe and I get good flow to the hydrant. We put the sections of pipe together with the hose barb style couplings and ran them thru the subsoiler, then put the hose clamps on in the trench. I made a dry run cutting along the path to help the depth and make sure there were no surprises before I laid the pipe. The pics are of a borrowed subsoiler but I have also bolted the same attachment to a KK subsoiler with similar results. I put some Yellow 77 in the funnel to lube the pipe.
   / Laying Water pipe #19
"Rocky Top"?
We actually named our road "Rocky Ridge Rd". The rock is even more of a problem when there's high winds like the tornados a few weeks ago. We figure we have about 300 trees down. They can only root a few feet deep at the most before they hit the rock. Over years, they gradually fracture it and send down little roots, but not strong enough to withstand 100mph or more.
But that rocksaw was really awesome! It would make about 2-3 ft/minute in most places at a depth of about 3-4 ft. Laying in 1/2 mile of 2" pipe with it cost about the same as drilling a well.
   / Laying Water pipe #20
I built this. Haven't tried it yet. It started out life as a KK middlebuster. I added the tooth, and conduit, etc.
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
Caterpillar 279-5360 72in Dual Cylinder Grapple Rake Skid Steer Attachment (A59228)
Caterpillar...
Flatbed Truck (A55973)
S/A Yard Dog Truck (A59230)
S/A Yard Dog Truck...
2015 Ford F-250 Pickup Truck (A59230)
2015 Ford F-250...
